Question about LG LRBC22544 Bottom Freezer Refrigerator
LG LFX25980ST REFRIGERATOR W/BOTTOM FREEZER SHOWS MESSAGE ON DISPLAY ER IF WHAT DOES THIS MEAN
  • 1,543 Answers
The control is not seeing a feedback signal from the ice room fan. (the fan inside the freezer which pushes cold air up to the in door icemaker) It is probably blocked with a build up of ice or frost, preventing the fan blade from turning.
Posted on Oct 20, 2009
SOURCE:
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
My lg refrigerator model GM-F228JTKA is displaying the message ER FF
The common service code ER FF is
Abnormal freezing
BLDC motor
Motor defect, hooked of lead wire
to fan, contact of structures with
fan, short or open of lead
wire(there is no signal of BLDC
motor more than 115 seconds in
operation of fan motor)
It appears you have a fan problem.
Feb 09, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
I have a LG refrigerator LFX25980n with FF failure, how to fix?
Is the freezer cold, but the refrigerator part is not cold?
If so, "FF" probably means fan failure. The fan which moves cold air from the freezer to the refrigerator is not working properly. The fix is to replace this fan.
Oct 09, 2009 | LG 24.7 cu ft Panorama French Door...
What does message: Er FF mean?
That means the freezer fan is blocked, you need to order a new High voltage board, the ice has built up enough from not defrosting that it is interfering with the operation of the evaporator fan.
Jun 22, 2009 | Refrigerators
LG Refrig LFX25960SB
The service manual with the codes is available at:
LG LFX25960 Service Manual
"ER IF" show a problem with the ice maker fan motor.
Nov 06, 2008 | LG LFX25960 Bottom Freezer French Door...
LG Refrigerator
That stands for a defrost heater problem. Usually it's the defrost detect circuit that has a blown thermal fuse.
Dec 16, 2007 | LG LRBC22544 Bottom Freezer Refrigerator
LG LRBC22544 Bottom Freezer Refrigerator Logo
372 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
deecee73
Level 1 Expert
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
