Follow the document
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01446637&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=2512009&lang=en
this is the best document that we can follow
other wise if your printer is in warranty call hp they will replace the printhead or the printer
SOURCE: Print Heads
Make sure the printheads are not expired. Check the dates. Order new from HP direct
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
SOURCE: The following printhead(s) has a problem Black/Yellow[K/Y].
Simple solution is:
Replace the Black and Yellow Print Catridges. The print heads are mounted to the bottom of the catridges and these, depending on whther they're from HP or not. can have a hard time conducting electricity properly, and in turn.. spitting ink out properly.
Also happens often with aftermarket Catridges because HP puts chips on the catridge. be sure to put an HP catridge. Sometimes you get what you pay for :)
SOURCE: L7380 is givinf errors on printthaed
This particular printer has separate ink heads and cartridges.
Call HP and complain about it not lasting the specified amount of prints and they might get it to you free.
Is this less than a year old?
SOURCE: I have the error: The following printhead has a
take it out. Shake real hard over a sink. Worked with mine after spending 30 minutes with support...
SOURCE: Hello, I am getting an error
Take it out and clean the contacts. Put it back in and see if the problem's gone. If not, buy new printhead.
I had the same problem plus had problems with message indicating "alignment failed" and to monitor the blakc/yellow print head. The print quality was very bad in black. It seemed to print about 1.5 lines and then skip a line. When I replaced black and yellow it seemed to get better print quality was just as bad. Finally called HP support. These are the steps they told me to do.
1. disconnect power
2. remove all ink cartridges
3. remove and clean contacts of both print heads
4. perform simultaneously the following press 6 and # on the keypad while at the same time plug in the power.
5. --- the printer came on (black squares on the screen) and then shut off.
6. --- was told to power up the printer
7. Printer began checking device(took a long time)
8. Printer began aligning printer (took a long time)
9. Finally finished = Message on screen "Alignment Failed"
10. Still not printing and hours later.
11. They will be replacing printer
12. Then they hit you with that you should buy a set of inkjet cartidges from them at $109.96 - warranty 2yr, works better, etc.
13. Sent to somebody else to arrange shipping new printer.
14. Free shipping 5-7 days - big deal - placed my work (home office) on hold.
16. Service help - listen when it follows the script, otherwise like talking to a door (In India).
17. Finally get transfered to somebody else and he informs me that he is not authorize to give me a new printer, need to talk to somebody else who is not there. Advises to call during business hours. He said that he could request that I be called back but that it could take a 1.5 days to get back to me.
18. I am going to call tomorrow morning during business hours - wish me luck.
I don't know what is awaiting but IN The Future I will not talk to anybody from INDIA - they do not have authority and do not listen (but maybe they don't listen because they can't do anything about it).
Good Luck!!
