Refrigerators Logo
Posted on Oct 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi My son just opened our fridge and it is
Hi My son just opened our fridge and it is full of smoke and same with the freezer
  • David Shaub May 11, 2010
    Is it smoke or condensation? If it's smoke, unplug it right away and get it checked. If it's condensation, call the weatherman.
Alan Chouinard
Level 2:
Scholar:
  • Expert 52 Answers
  • Posted on Oct 20, 2009
Alan Chouinard
Expert
Level 2:
Scholar:
Answers
52
Questions
Helped
18224
Points
162
I can think of only one thing that would make that much smoke. and that is the electric defrost element has shorted out. this is located in back of the freezer compartment. there should be a series of screws that hold the panel on. remove them and check it out with a flashlight. the element runs along the evaporator coil. it shouldnt be too hard to see if the element is bad. get a meter and ohm it out if all else fails.
1helpful
Hi I have an old american style 4 door zanussi fridge freezer recently the freezer defrosted itself and the red warning light is now flashing since. The fridge above is still working fine. Sorry don&#
As far as I can tell the fridge and freezer are on two separate compressers so if one gos down the opposite will still work. As for the red light I can only think if the unit is not working that the defrost is stuck open, or the compresser relay I stuck open, or the compresser is shor, or t-stat is stuck open od there may be a drain pan sensor and it is full and not evaporating. Sorry that's all I got
Hi, M fridge at times has lots of condensation around the inside top and the freezer at times has when you open it has lots of like smoke thanks jackson
you are not getting a complete defrost. and mosture is building insde / card board is soft with mosture, ck the drain and the defrost heater's and the defrost terminator . these would cause the problem hope this helps mm
GE bottom freezer model PDS22MBRBWW gets too warm
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
2answers
Freezer not working
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
heatman101
Apr 17, 2010 • Freezers
Whirlpool side by side not cooling
check behin the fridge. try listen the compressor. not hear the com.? maybe time for a new fridge. unless is under full warranty
3helpful
When we open the freezer door, a lot of steam/smoke comes out. A lesser amount comes out when the fridge door is opened.
If the fridge is working and keeping things cold and frozen, you don't have a refridgerant leak that is producing vapor that might appear as steam or smoke.
The steam/smoke is actually water vapor being made visable due to the temperature difference between the freezer/fridge temperatures and the air temp in the room (or garage) the appliance is in.
It's nothing to worry about and is normally more likely to happen when the outside or house air temp is very warm (Summer months) and when the air is humid.
What's happening is the very cold and cool air is hitting and mixing with the much warmer and much more dense air (humid air contains microscopic water particles) when you open the doors, and is instantly being cooled. Thus it appears as thou the fridge is steaming or smoking.
Have a great day an hope this explains the situation. Best regards.
My son got into my fridge lastnight-left open, now won't cool
evaporator coils is probably frosted from condinsation.shut door set at normal setting and give some time.
Noisey fridge freezer
Please check the fallowing:
-Loose flooring or floor not firm.
- Cabinet not level.
- Tubing in contact with cabinet, other tubing or other metal.
- Drip tray vibrating.
- Fan hitting another part or worn fan motor bearings. Unplug the unit and rotate fan manually by your finger.
- Compressor mounting grommets worn or missing; mounting hardware loose or missing.
- Free or loose parts causing or allowing noise during operation
- Check compressor it may contact with tubing or other parts.
- Check the body of your unit is not touching the wall or other object
Jan 25, 2008 • Freezers
BEKO FRIDGE FREEZER
The best way is open freezer door wait 30 seconds then shut if the door pulls shut further then machine is working if not not working.
Thanks J
Dec 23, 2007 • Freezers
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
