Using hp laserjet p3005n, when I print one page it sends blank pg
Using hp laserjet p3005n, when I print one page it sends out 1 blank page and 1 page with user, host,class & job along with the page I printed. How do I make it stop?
Re: Using hp laserjet p3005n, when I print one page it...
Annoying but easy to solve.
Go to the printer's ip address management page from a web browser. Look under the TCP/IP address settings. Click on the advanced selection. Disable the LPD Banner page. That should fix it, if it's not under advanced poke around until you find LPD Banner Page. ;)
try to remove the dimm. try to switch on without dimm. it not successfully than try to check the cables from the power board to the formatter. try to push them in thir place. If this is not successfull too than it is a formatter problem. try to change the formatter
Sounds like a Procomm issue. Since I am not familiar with Procomm I can help you any further. But here is my analysis: All other application except for Procomm prints to tray 2. That is because all those applications use the setting as configured in your printer properties in Windows. What Procomm seems to be doing is trying to load a special paper from the manual feed tray, that is tray 1. You will have to check with in this Procomm application where you can change the printer properties so you can specify it to use tray 2 as the default. This is all within Procomm and has nothing to do with Windows nor your printer.
hp3015 user host class job
