Question about Watches
Aw60453w can't turn off alarm or hourly chimes
Aw60453w athletics works watch lost instruction manual cannot turn off alarm or hourly chimes.
SOURCE:
How to turn off the alarm?
http://www.freestyleusa.com/support/
the second window down has the buzz instructions.
in the buzz instructions
TO TURN ON/OFF THE ALARM AND
HOURLY CHIME:
1. Press S3 button to select HOME ALARM or FOREIGN ALARM to set. 2. Press S1 button to activate the alarm. Alarm indicator /
will appear.
3. Press again to activate the hourly
chime. Chime indicator will
appear.
4. Press the third time to activate both
functions. Both of the indicators
will appear.
5. Press fourth time to deactivate both
functions. Both indicators will
disappear
May 30, 2014 | Freestyle Shark Buzz Wrist Watch
I cannot set the time on a wr165
here's a simple instructions of setting your watch
Watch setup instructions
for the Armitron Instalite All-Sport :
Mode B / \ C Date
Light A \ / D Alarm
_____________________________________
Set time time / date
Press and hold B (Mode) untill alarm hours flash
Press D (Alarm) to advance these
Press B (Mode) again, seconds will flash,
press D (Alarm) to advance these
Press C (Date), minutes flash, press D to advance these
Press C again, hours flash, press D to advance these
Press C again, month flashes, press D to advance these
Press C again, Date flashes, press D to advance these
Press C again, Date flashes, press D to advance...... [suggestion from Chikita]]
Activating/Deactivating Hourly Chime
1. From "Normal Time Mode", press and hold "D" (Alarm) and
at the same time press "C" (Date) once. Hourly chime symbol,
( a house shape) appears in "chime" windows to indicate
the hourly chime will beep every hour.
Activatin/Deactivating Alarm
2. With "D" (Alarm) still pressed, press "C" (Date) again. Alarm symbol
( a clock shape with waves above it) appears in the
upper right to indicate the 24 hour alarm is now activated.
[I assume this "toggles" between off and on states,
so performing it again should turn off the alarm]
i hope this will help you.
Jul 22, 2011 | Armitron All Sport Digital watch
How do I turn off chime?
Hello Mfchester,
Here are the instructions to turn off the chime on your Timex Sports 1440 watch. Please let me know if I can be of further assistance! :)
--Sandy
ALARM AND HOURLY CHIME INSTRUCTIONS:
  1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
  2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
  3. Press START/STOP to select MINUTES.
  4. Press ADJUST to change.. Press MODE when done.
  5. Press and hold ADJUST, then press START/STOP to turn chime on/off.
  6. Press START/STOP again to turn alarm on /off.
  7. Release START/STOP when done.
Note: Please remember to rate this post if you found it useful.
Apr 19, 2011 | Timex 1440 Nylon watch
How do I turn the alarm off on a Athletic Works, AW60442W
I have the AW21312W, which has 4 buttons:
  1. Light (Top left)
  2. Mode (Bottom Left)
  3. Start/Stop (Top Right)
  4. Lap/Reset (Bottom right)
To turn the set alarm off, push buttons 3 and 4 at the same time, the alarm icon should appear or disappear
To turn off the hourly chime, press button 4. While holding it down, press button 2 and the days of the week disappear. The chime is now off. If you want the chime, press button 4 and hold while you press button 2. When all the days show, the chime is on.
Apr 02, 2010 | Watches
Athletic works watch owners manual
if you press both buttons on the right at the same time it might work. Im not sure if it will for ur model, but it worked for mine =)
Aug 17, 2009 | Watches
I need instructions for Athletic Works AW60442W
hold bottom right button, press bottom left button. if all the days of the week are highlighted then your chime is on, if not your chime is off.
Mar 29, 2009 | Watches
Casio G-Shock alarm not working
The alarm should be sounding. (broken?) To turn hourly chime on and off, go to alarm screen and select SIG. Then top left button turns it on and off.
A -- B
( ) Button reference
C __D
6) Hourly Chime (SIG):
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG).
Press D to select hourly chime (SIG). Press A to toggle chime on and off.
Press C to return to Timekeeping mode.
Good luck,
Techjoel
Feb 04, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Turn off hourly chime
switch to alarm mode and use "C" the select button to switch it off.
Jan 05, 2009 | Casio G-Shock GW500A-1V Wrist Watch
I just bought an Athletic Works watch at WalMart that is identical to the Aquatech watch I bought there some years ago. My band got hard and cracked so I needed to buy a new one as the band is not available. For $9 the entire watch is probably cheaper than a band. I used the instructions from my Aquatech to set the stuff on the AW. I found the instructions on the internet. Here is one site that has them.
http://www.ehow.com/how_4587869_set-aquatech-watch.html
Give it a try.
Clem S
Sep 23, 2008 | Watches
Innovage Gear wristwatch beeps every hour
To turn off the hourly beep: While holding the lap/reset button down, press the mode button. When all 7 day flags show, the hourly chime is on. When no day flags show, the chime is off.
Mar 11, 2008 | Watches
Watches Logo
4,072 people viewed this question
Top Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
