Cell Phones Logo
Posted on Oct 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Forgot my sim pin now lock need puk code
Forgot my sim pin now phone is lock need puk code its a sidekick lx thank u
Anonymous
Level 3:
  • Master 400 Answers
  • Posted on Oct 20, 2009
Anonymous
Master
Level 3:
Answers
400
Questions
0
Helped
113696
Points
1295
Sir,
You will get the Puk number from you connection services center and you will be required to take you NIC card with your self.
1helpful
Well I need my Sidekick LX to be unlocked to my local network (Digicel Jamaica) and I wanted to get the code as fast as possible I really need help with this
You can unlock the Sidekick LX from Jamica Network digicel using the Unlock code ,you can get the Unlock code within 0 to 5 Hours(approx) you can get the code at reasonable cost here Simpleunlocking.com and Unlock it ,then you can use it with any GSM Network Sim card....Follow the instructions below and Unlock it step by step...
Sidekick LX Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Sidekick LX mobile phones. If you enter over a certain amount of wrong unlock codes on your Sidekick LX mobile phone, your phone may get hard locked and sometimes become unusable.
1. Switch ON your Sidekick LX with a Not ACCEPTED SIM Card.
2. If your Sidekick LX asks for a PIN code, then enter your SIM card PIN and press OK.
3. Sidekick LX will ask to enter an "unlock code".
4. Enter Unlock Code we send to you.
5. Your Sidekick LX is now unlocked.
*NOT ACCEPTED : We mean, to use a Sim card from a network other than the network your Sidekick LX is locked to.
My sidekick lx 2009 didnt ask to enter code, plz help me thanks u
It says just Network lock only,You need to enter the Code if it locked Network mean.You can get the Unlock code at here
http://www.superunlockcodes.com/sidekick-lx-2009/rs12wp9/ and Unlock it,get the Unlocking Instructions below to unlock it step by step.
Sidekick LX 2009 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Sidekick LX 2009 mobile phones. If you enter over a certain amount of wrong unlock codes on your Sidekick LX 2009 mobile phone, your phone may get hard locked and sometimes become unusable.
1. Switch ON your Sidekick LX 2009 with a Not ACCEPTED SIM Card.
2. If your Sidekick LX 2009 asks for a PIN code, then enter your SIM card PIN and press OK.
3. Sidekick LX 2009 will ask to enter an "unlock code".
5. Your Sidekick LX 2009 is now unlocked.
*NOT ACCEPTED : We mean, to use a Sim card from a network other than the network your Sidekick LX 2009 is locked to.
Each Sidekick LX 2009 mobile phone has an unique unlock code. You can buy the unique unlock code for your Sidekick LX 2009 mobile phone using the form above.
Como unlock my sim puk my sim card been sicurity locked care for a puk
A request for a PUK code ("Personal Unlocking Key") will appear on your phone if your SIM card PIN code is entered 3 consecutive times incorrectly.
Your SIM card will then become "PUKed" or Blocked. This is a security measure to protect your service.
You need to call the Customer Service department of your cell phone provider and they will give you the PUK code which will unblock your SIM card.
2helpful
I locked my phone and it says i need a pin1 pin2 and puk what is the puk for a Sharp FX
I set a lock code and forgot pin
HI If you are asking for pin contact your service provider , he will give you a default pin .
If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider which is specific for each and every mobile number . Do not try PUK(new pin code) code many times or else your sim will be blocked and you will need a new sim.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software.
2answers
My Sidekick LX is asking for a "Special Code"
once it says to enter your "special code" you hit cancel and it enables the sim pin. then you go to change sim pin, put in your old sim pin and put in a new one. then go to network settings and select "scan and select manually". once you find at&t click done and you can use the sidekick.
Phone request me to enter the sim code when i used Cambodia's SIM
not sure if this works with the 2008 but its something you can try, i put a sim card in my LX and was asking for a special code to unlock the phone, well right now tmobile isn't unlocking the sidekick, but you can trick the phone into using the sim card. First go to your settings, go to "SIM Center" and click on disable sim lock, enter in whatever your sim password is (if you dont know your sim password get your PUK (pin unblocking key) number which customer service will give you if you call 611, you can change that SIM pin by typing **05*PUKnumber*newpin*newpin#) now if you wanted to change it to "0123" if your puk was 9483992 its 7-9 digits you would type **05*9483992*0123*0123# now your sim pin is 0123. (trying not to make this super complicated) it will say sim pin not accepted click ok, now click change sim pin you can type the same sim pin 3 times if you want, 0123 0123 0123 now at the top of the screen bars will show up with a white phone beside it, go to Settings-Network Options-Scan and Select Manually, the SIM network should come up, click ok when it finds it and it will connect, now you can call and text on whatever sim you have in the phone
7helpful
3answers
The special sim code for the sidekick lx
just ask the phone company provider for your PUK2 AND PUK codes.
when you get them go to the jump menu dial
**05*PUK*passcode*passcode#
the passcode is any 4-8 digits you'd like, that are NOT, AND I REPEAT N - O - T consecutive.
(for example 2736 is good whereas 1234 or 9876 is bad)
if it asks your for the code again put in the PUK2 then go to settings> network options goto the "scan and select manually" button and chose your carrier.
87helpful
17answers
How to unlock special SIM code on Sidekick LX (T-Mobile) from USA
works for sk 3, slide and lx.
the video says only at&t in the U.S. but... i've seen it work for fones in europe.
try it.
4helpful
3answers
Unlocking sim card
Okay well first push the button on the top left side and push L and that should unlock it it worked 4 mine....Okay tell me if this works
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
