Just bought new Samsung tv, does anyone know the code I enter on the tv remote control to be able to also operate my sky plus box (pace)
0060 does not work with my model of Samsung (
I found the code can vary according to the particular Sky Remote you have.
Look in the battery compartment for the version (it will say something like Rev 8R or Rev 9F)
For my model I found code 1647 worked with a Rev 9 remote but not with a Rev 8 remote
I found codes 1277, 1340 and 0646 worked with a Rev 8 remote but not with a Rev 9 remote
Other codes that worked with certain older models of remotes included 2079, 1177 and 0088
With your Sky + remote.
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0060
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
SOURCE: I need to find out how to program my samsung RS-105N remote control.
The picture you have is a Directv universal remote.If that is correct.
Turn your Tv on.
Press and hold the TV and SET button until the TV button lights up. 4 seconds or so.
Release the buttons.enter one of the 3 codes below.If the TV turns Off you have the right code,press the TV button to lock the code in.repeat if the code does not turn the TV off
for Panasonic the codes are 034 or 080,056, 164
SOURCE: Samsung Remote code
Hi Friend
My Samsung TV Model is : CS21S67WX/XTML
Serial No is: 0151-32ARC00985Y
I need to use ir remote through my phone so May i know the remote code for this model pls send me a reply at: [email protected]
Basha
SOURCE: need code for sky remote control for samsung model
Hello 065 584 615 037 245 476 516 292 318 236 398 244 100 118 060 088 646 672 642 Follow the steps below 1. Select any channel on the TV. 2. Point your Sky+ remote control away from the TV and press the tv button. 3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice. 4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice. 5. Point the Sky+ remote control at the TV and try the volume button. If this works try the other TV functions. If these work then the correct code has been selected. It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture. If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Sky remote codes for Samsung TV are:
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
I have this problem also, SKY are a waste of time.
