SOURCE: i want sent txt by mms on my samsung inno8 phone
Since there's no separate MMS message menu on Samsung, you wont be able to send a normal and simple text message as MMS, but if you wish to send text only without any graphics or multimedia, you can try inserting a multimedia like image or sound clip before you start editing the message, after that type in the text and delete the multimedia content once you finish entering the text. This method works on Gorby, I've tried it myself. But I am not very sure whether it's the network or the model.
It's also not recommended to sent text message as MMS since you would be charge for the service. As long as there is no multimedia content, I would suggest you to send text only message as text message instead of MMS.
If my assumption is wrong, please clarify with more details.
Good Luck.
Thanks for using FixYa.
SOURCE: i sent a txt message
IT HAD SENT THE MESSAGE AND AFTER THAT WHEN YOU HAVE COME OUT OF THAT MENU IT WOULD SAVE THAT AS A DRAFT
SOURCE: samsung S8300 MOBILE PHONE TXT SOUND ONLY WORKS
Maybe you need to replace the flex cable, check this:Flex Cable Ribbon Flat Connector For Samsung S8300
