Motorola Mobility RAZR V3 Logo
Posted on Dec 29, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Security code there is a security code on my phone and i forgot it is there a master security code that i can get its a motorola razr v3
  • 6 more comments
  • gemstoned Feb 01, 2008
    locked out need PIN1 unblock code
  • Anonymous May 10, 2008
    what if the code is not 000000
  • Anonymous Jun 23, 2008
    ive forgotton the security code thats reqested when i turn my phone on so cant do nothing with it is there a master reset code my phone is a nokia 5310
  • qgmetroman Jun 24, 2008
    cant remember my security lock code
  • wolfminer Jul 25, 2008
    need a security code
    the 000000 did not work for the security code it says its incorrect
  • b46290girlie Nov 25, 2008
    security code's not 000000,what is it?
  • bittenben167 Mar 27, 2009
    might have changed my security code at one pt but i forgot it, and its not 00000 or 12345 or anything like that, and now i cant get into my lovely phone.
Anonymous
Level 1:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Dec 29, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
1240
Points
7
The code for master reset should be 000000
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jun 25, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
1291
Points
12
I got same problem with my phone .i got the solution.
just go 2 google.com then type (motoblaze) basicaly this is unlocking software but it can solve the problem of security code u forgot. just install this software connect ur phone .and follow the instruction . when it goes 2 (third) 3 test option it will show ur security code & phone code .
Anonymous
Level 3:
President:
  • Master 1,017 Answers
Anonymous
Master
Level 3:
President:
Answers
1017
Questions
0
Helped
974694
Points
2767
Your service provider can reset you mob with a PUK number.
Or
Go to:
http://www.kingmobilephone.com/pages/motorola.php
A
Anonymous
If your phone is capable of resetting to factory defaults then do so most of the time it doesnt require a passcode and it resets everything...........
3helpful
Need master code for nokia e61i as i got it locked and forgot the code
hi
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
1helpful
Forgot my cellphone security code
Unfortunately a master reset is in order, go to master clear. It will ask for a security code. It should be six zeroes (000000). This will erase everything on the phone- contacts, texts, etc.
4helpful
3answers
Lost unlock code
Depending on how many modifications, hacks, or customizations that you perform on your Motorola RAZR V3 phone, there may be situations where the phone becomes unusable or completely locks up. I have had visitors to the site report not being able to delete ring tones, text messages, or have other strange behaviors with their Motorola RAZR V3 phone.
If this is you situation, then you may be interested in performing a master reset (or “hard reset”) on your phone. The master reset will effectively restore your phone back to the factory condition, inclusive of all settings. Be warned, any data that you have not backed up, photos you have not transferred, calendar settings, or messages you have not saved will be lost! Make sure you do this first, if possible!
Here is how you perform a Master Reset on the Motorola RAZR V3:
1. Open your phone up and go to “Settings”
2. Next go to the selection for “Initial Setup”
3. Next go to the selection for “Master Clear”
4. Then select to confirm the option.
5. Now enter the security code which should be “000000”
6. Finally press select or ok and the phone will reset itself to the factory condition
Congratulation you have performed a “hard reset”, “hard reboot”, or “master reset” on your Motorola V3 RAZR and it should return to normal operating mode!
Trackbacks that led to this post:
hard reset motorolla razr v3
hard reset razr phone
wii master reset
hard reboot motorazr
how to hard reset a razor v3
master reset code for motorola v3
master reset code razr v3
master reset for v3 via pc
master reset motorola razr 2
master reset v3 razr with white screen
motorola v3m master reset
p2k commander
razor master reset
razr 3 and how to reset
razr master reset ebay
razr master reset password
razr master restart
razr screen master reset
reset razr
reset razr to factory
reset razr v3 to factory
v3 hard reset razr
v3 razr reset hard boot
Forgot my security/lock code
phone power on when ask pass work
Press menu and * and then enter 6 zero and press ok.if not re-load software.
2helpful
2answers
V3 master reset
well it is usually 000000 but if you have forgotten it then you will need to take the phone to a service center and have them reset the codes for you.
2answers
Master reset
Yeah try the last 4 digits of your phone number or your SS
1helpful
3answers
Ive forgot my unlocking code for motorola phone
well let's hope that you did not change the security code, tell the person to press the menu key and when the screen ask for the security code tell them to put in the 000000....that should help
3answers
How to unlock my security code
ranjithnairv + hardknox - press the menu key in the middle of the keypad, scroll to initial setup then select either master clear or reset and enter the 000000 as the security default codes.
all others take the phone to a mobile service center and have them reset the phone codes back to the originals for you.
23helpful
11answers
How do i master reset my phone?
unfortunately there is NO pin hole to reset the mot v3,
just goto initial setup and chose master reset and use the sec code 000000
if u have changed the security code then use the one u changed it to, the motorola V3 is not a wifi modem :/ There is not pinhole
to reset the phone :O
if u have changed the security code and cant remember it
msg me and i will show u how to retrieve it.
wbr
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
