When im playing mercenaries 2 the scenery just goes away and depending were u are u fall and its not the game because i have tried different game discs
If its just this game that is doing it, then the disc may be dirty or scratched. Try cleaning it with a dry duster (wiping the disc from centre to edge). It that doesn't work, then have a good look at the disc for any scratches. If you do find any, then the disc is probably broken.
It crashes because of EA :) They have problem with their servers and I think they've been shut down servers for a while. That's why you can't play online. But when I play offline, I can't save the game in any point or otherwise it says "Save failed" for plenty of times. I don't know why :)
The game itself is just defected. You might be able to find your answer in this thread http://www.gamefaqs.com/boards/932882-mercenaries-2-world-in-flames/45193926
Problem seems to be the XBOX Hard Disk Drive (HDD). Run the game and play it once for about 30 mintues, then try again with the HDD inserted. It should now work.
The problem seems to be a conflict with the HDD or with the EA servers, as the XBOX Live account will try to connect to the now dead EA servers for this 2008 title.
If all else fails, you will need a portable memory card, not the HDD to play this game. It's okay if this is the case. Create an offline profile. The game no longer connects to the EA servers anyhow.
Download the demo of army of two accept ea's terms and conditions start game quit put mercs 2 back in and it should have sorted it but if not you need to borrow rent or buy the full game to get your problem fixed. This is the same problem as the freezing on the main menu.
Well your disc is officially garbage because it's scratched for sure. Don't bother trying to fix your game disc. Do what I did. Go to sellitbroken.com and sell your game to them. They will give you good money for it.
make sure the disk is clean and the lens is clean in the machine if you've cleaned both and it still freezes try puting a small 1 inch piece of scotch tape on the printed side of disk it'll switch the ballance and cause it to spin slightly different which may get you passed the skip
sounds like the laser's stuffed. the lasers in those machines are notoriously bad. you'd best be careful. a dodgy laser will cause laser-burn to the discs. i had the same thing on my machine. i could play a couple of games, then there was some that would work after i took them out and put them in, several times. after fixing the laser, ive not had the problem again.
