your fax RX memory is full and needs to be cleared however this should not stop you from sending transmission TX immediately however if you are going to send a memory fax you will have to clear the memory for machine to be able to store the TX you are trying to send
hi, HP Officejet 5610 All-In-One InkJet Printerhas few common problems. Such asDriver CD lost,Scanner does not work,Connection problemetc. For find all these software solution just clickhere....
press the # and no 3 button together on the printer while its on
now remove the power cord from the printer
and while pressing the # and 3 button insert the cord again and release the button
A reader posted the way for me to do it. I needed to go into the menu and click on the tools bar. Then I right arrow tabbed to get to the fax section. Then right arrow tabbed to get to the memory section. Then right arrowed to get to the clear memory location. Then pressed okay
Press the Right arrow button ( ) until Tools displays on the control panel, and then press OK .
Press the Right arrow button ( ) until Fax Log displays on the control panel, and then press OK .
Press the Right arrow button ( ) until Clear Fax Log displays on the control panel, and then press OK . A message that says the fax memory is clear displays on the control panel.
Press the Right arrow button ( > ) until Tools displays on the control panel, and then press OK .
Press the Right arrow button ( > ) until Fax Log displays on the control panel, and then press OK .
Press the Right arrow button ( > ) until Clear Fax Log displays on the control panel, and then press OK . A message that says the fax memory is clear displays on the control panel.
recently purchased a J6480 All in one. The fax function stopped working and the message was "Fax Log Full" cannot send or receive. How do I fix it? K. Kirschner [email protected]`1q```````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````
