Whirlpool GBD307PDS Electric Double Oven Logo
Anonymous Posted on Oct 19, 2009
I replaced the control board in a double wall oven 3 weeks ago, everything worked fine until yesterday,now the upper oven when we set it for bake and then push start the control panel lights completely up and then all the lights go off and it shows a pf and won't heat. the model# is rbd305pdb15 and the control board # is 8302319
Anonymous
Level 3:
  • Master 725 Answers
  • Posted on Oct 21, 2009
Anonymous
Master
Level 3:
Answers
725
Questions
0
Helped
167343
Points
1617
PF simply means a power failure and simply needs to have the breaker reset to accept the new board that you replaced. There are times when you may need to replace the breaker that controls you oven electricity.
GE model JKP28BOF3BB. Bake button for upper oven isn't working. Replaced thermo sensor & control board already with new ones. No change in problem with upper oven baking & I have no fault codes appearing...
If you're running a double wall oven as displayed here, you would need to replace the control panel in the front that has the green little ribbon cable on it to solve this problem, I actually imagine that that part unfortunately may not be available anymore, however you could call parts and check availability at 1800 626 2000 This is also known as the keypad assembly.
Dec 14, 2018 • GE Ovens
I have a brand new Viking french door oven...Went to set it at 450 on bake setting and got an F02 error code. How do I fix this?
Fault F02 is indicating an overheat fault- service manual says to replace main electronic control board.
Sometimes switching off at wall will clear the fault.
However, switching off at wall will reset the clock- you need to set the time before the oven will work-press middle button until small triangle is next to clock icon, set time using temperature dial. Once clock has ben set, try using oven to see if F02 fault reappears. Good luck!!
Frigidaire double convection wall ovens, model GLEB30T9DSA ... The top oven will not heat, both the bottom element and the broiler.....
I have the Frigidaire PLEB30S8CCA single wall oven. About 3 months ago the baking element appeared to have gone out. We replaced it, but still didn't work. We ended up sending our control board off to a company named Corecentric. They fixed the problem and returned it to us. The oven has worked perfectly ever since. I searched extensively for a new one, but no one sold them anymore. I found Corecentric on Ebay. They were able to confirm over the phone that it was more than likely a control board issue. It cost about $130. My husband was able to do it himself by taking a couple before px and using them when reassembling it.
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Frigidaire oven
Yes, that sounds like a relay on the oven control board. Here is the part to order that has a 365 day, any part, any reason return policy so you may want to order from them.
Jun 25, 2013 • Ovens
I have a frigidaire 30" wall oven GLEB30T8CBA.
The control on the upper bake element has failed.and needs to be replaced
1helpful
Temp control stopped working properly
replace the electronic control board.the power surge may have damaged the boards circuits.
4helpful
3answers
The upper oven works fine. The lower oven won't
Make sure you hit the reset switch first... on top of the lower over... behind the panel...they trip easy and "kill" the oven.
Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Thermador double oven / Bake wont work /FC code flashed once
I found I have this exact problem. Same bake preheat issue: I can bake if I set broil first. However, the oven doesn't work if I press bake first. The control board has already been replaced a couple times over the years. Is this another replacement??
Top Whirlpool Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
