I need a wiring diagram for our General electric Fridge Freezer, model number PCG23 NHMFFBB. Can any one help.
I don't like the idea of someone just recharging a system without knowing what's truely wrong.
At this point, based on what you've said, I strongly recommend you call G.E. factory service or a dealer with a qualified service tech in the G.E. line.
G.E. has made the use of a lot of solid state boards, which may well be some if not all of your problems. It will be pricey, but a refrigerator is not a toy. I would advise the tech as well, that you had a recharge performed, and let him follow up on it.
Sounds like whoever worked on your machine isn't well qualified to service it. Newer G.E.'s can be a real bear. Sorry....
Hi.
I have some one looking at the problem and he has said that he might be able to solve the problem if he had a wiring diagram.
The problem is that the fridge/frezer won't get cold enough.
Had it re gassed.
Fan was not working, so replaced and still not working.
WIring diagram might help.
Thank you
Fridge is 5 years old and the evaporatop fan motor was replaced.
How old is this refrigerator? A wiring diagam would be needed for electrical problems only. If it was recharged using R134 then you could be on a slippery slope. If your saying the fan motor was replaced, which one? The one on the bottom called a condenser fan motor, or the one in the freezer, called an evaporator fan motors.
Could you explain why you need a wiring diagram? May be able to help you better, if you reply.
