Think of where the transducer is fitted on your boat . As turbulence is the only problem you need to worry about. It needs too be on the transom but in between the lower 2 chines
Usually the simplest solution is a great place to start. Start by checking the supply, fuse, and power button. If this does not look like its getting you anywhere start at the power supply circuit inside the unit. Quite often a defective supply voltage or reverse polarization blows some of the capacitors and/or reverse protection diode on this board. Also ensure that the unit as a whole is off and not only the display. Try to listen for the "on" beep to start with. If that isn't there whip out your multimeter and check like above. Good luck.
hello there:
here is a link that will help you get the manual u need ok?
best regards micha Eagle 250 DS - FishEasy GPS
Learn more about the Eagle FishEasy 250 DS before you decide to buy. Download User Guide and Manual...fish finder EAGLE FISHEASY250DS. www.bestfishfinder. ...
www.retrevo.com/s/Eagle-250-DS-GPS-review-manual/id/23493bh848/t/1-2 - 69k - Cached el
