Razor E100 Electric Scooter Logo
Posted on Oct 19, 2009
I need the controller diagram to fix my razor E100
Anonymous
Level 1:
  • Contributor 36 Answers
  • Posted on Nov 06, 2009
Anonymous
Contributor
Level 1:
Answers
36
Questions
Helped
27237
Points
70
Hope these help - the first image is the top of the PCB
How to fix my razor scooter e100?
The E100 is a Kick Start scooter, the Rear Wheel has to be Spun for it to start. This scooter will not start from a motionless position.
Could be the battery.
Put the Scooter on a block so the rear tire is raised. Remove the standing plate to reveal the battery compartment.
Charge the Unit completely
1. Using a multimeter measure the voltage across the batteries. If the voltage is below 20 volts batteries are dead - Replace batteries.
2. Now for a running test. Turn the throttle and spin the rear tire to preform a kick start. Still measuring the voltage. If the voltage is Below 20 volts or if the voltage drops quickly batteries are dead - Replace batteries.
3. If the voltage is remaining around 24 volts for a long period - then you could have connector problems, clean and tighten all connectors.
I use a fiberglass electronic cleaning brush, as contact cleaners leave residue that interfere with electrical connections.
The control module is simple and can be replaced with only a 24 volt relay without the kick start feature or Brake. If you want the brake then you can use two 24 volt relays still no Kick Start.
For those of you who know electrical, below is circuits I developed to replace the controller. This diagram will also give you a better understanding on the Razor circuit.
NOTE : This is not a schematic diagram of the Razor E100 Control Module. I designed this circuit. for my Great Nephew's Scooter.
1. The Brake is a normally closed switch that opens when you squeeze the Brake handle.
2. The throttle is two normally open switches that close when you turn the throttle.
3. The Kick Start circuit is described in the Diagram below.
4. The resistors values may need to be tweaked for best performance.
Google Link to what could be the Electrical Diagrams for E-100
How to reset the razor E100 ?
There is a reset button by the on/ off toggle switch I believe. Also, the e100 needs to be pushed to about 2.5 mph before it will go on its own power.
How to fix Razor e100 troubleshooting
May 22, 2014 • Cell Phones
1helpful
No power
Battery razor e 100 replace
I have a ct-811b9 controller with my electric scooter and i un-hooked a connection and the controller almost littereally exploded and now the throttle does not work. i bought a new controller and now the...
  • Replacement 24V controller with 4 pin throttle connector
  • For Razor E100(Versions 10+), E125 (Versions 10+), E150 (version 1+) and E175 (version 18+) eSpark(version 41+), Trikke E2(versions 1+) electric scooters.
  • Replace Razor part #: W13111612164 Model No: ZK2400-DP-LD-ROHS7, ZK2400-DP-FS-ROHS7
  • The E100 series Razor scooter is a PUSH START scooter. You need to push the scooter, twist the throttle and then the motor will engage
  • 1-Year Warranty - Money-back satisfaction guarantee
7 connectors, 5 plastic connectors & 2 metal connectors
2helpful
Wont charge tryed a new charger think its the battery can i replace the battery ?
Razor E100 batteries are easily replaced & there are guides on how to this on razor.com, genuine Razor batteries are available at most good Razor product stockists.
How can you fix a e100 razor electronic scooter when it wont move?
Fitted New on and off switch also new reset button. Battery ok but will not start
Its apart
Click the link http://www.razor.com/support/pdf/manuals/current/e100-series-manual.pdf
Scroll down to page ten, it has a full exploded diagram of the scooter.
Re-assembling a E200 rear wheel
Click this link http://www.razor.com/support/pdf/manuals/current/e100-series-manual.pdf
Scroll down to chain and tire replacement. It has a full exploded diagram of the rear wheel
Top Razor Toys Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Kardoc
Are you a Razor Toy Expert? Answer questions, earn points and help others
