Hi
Thanks for using FixYa. There is an over-temperature switch built into the
electrical panel of the oven. Resetting this switch solved my problem.
To reset it: Turn off the power. Open the door (if door is locked, turn the
power back on and gently try pulling the door every few seconds as the locking
mechanism cycles until it is unlocked). Remove the 3 screws below the control
panel (screws point upwards, with the head just inside the oven). Pull off the
face of the control panel. Let it dangle by the wires so that you have access
to the space behind it.
Within the electrical enclosure exposed by removing the control panel, look for
a small silver and black device with 2 wires attached to the back. The device
is about .5" wide by 1" long and is attached with 2 screws to the
sheet metal on the bottom of the electrical enclosure.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
