Hi, If you have a gas dryer.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric..
There could be a number of different problems...
Check out this whirlpool dryer wont get hot - 2_bing.gif wrote about this problem...
Dryer Trowhirlpool dryer wont get hot - 2_bing.gifng Electric Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
SOURCE: my whirlpool dryer wont get hot
Does it heat up at all? If so, your vent may be clogged. First check the air flow to the vent. If it vents straight out from the laundry area, be sure it's got good air flow. If it ventys up inside the wall, you need to have the vent cleaned out for saftey reasons. If it does vent up, you could have a house fire. Or your safety t-stat or thermal fuse may be out. Call us for parts! 9728590929. Hope this helps you!
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
