Why make it so diffacult keep it simple for us electronic handicap
You need to enter the Router's Menu. Its web Based you can type http://192.168.1.1 from your web browser to get into your Router's Menu. It might come up with Username and password request put "admin" for both of them (its default).Since the Menu is very easy to understand you will find all settings including security that you needed. Make sure your laptop had DHCP enabled and Router connected to computer.
Good Luck
Hi Again
Answer is simple; network security (WEP or WPA) key is different than regular password. Entry should be Hexadecimal, However you can use pass phrase generator by entering regular characters or you can enter directly. For example if you we want to put to "password" as network key hexadecimal input will be exactly 2B204A3F1042643E480FDD655E for 128 Bit WEP.
Hope you will resolve the issue.
Good Luck
Thanks the "Admin" was the key
Now my next problem...
I went to set a password, set one and now it comes up with WEP and when I put the password in it says it is incorrect and I don't know how to get around this now
