NRS Kayak Tow Line Logo
Posted on Oct 19, 2009
I have recently purchased a Freedom Hawk 14 fishing kayak for saltwater shallow water fishing. I want to tow the boat behing my motor boat to the location of the shallows since it is a very far distance. What is the best method for towing an unmanned kayak from a motor boat?
Anonymous
Level 1:
New Friend:
  • Contributor 17 Answers
  • Posted on Nov 12, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
17
Questions
0
Helped
7912
Points
37
Don't tow it behind you, but strap it alongside your powered craft with short lines bow and stern. The kayak should be snug to the other boat
What safety measures should I take when doing kayak fishing?
Its vary exciting to go for kakayk fishing, But you have to know some tips for your safety. Here i give some tips when you go for kayak fishing.
  • Be aware of weather conditions and water temperature. Prepare for changes in weather and the possibility of a capsize. If paddling in cold water, a wet suit or dry suit can keep you warm and comfortable. In warm weather, a long sleeve shirt can provide sun protection.
  • Invest in appropriate clothing for your climate. One advantage of sit-inside kayaks is that you can shield yourself from some of the elements, while sit-on-tops leave you more exposed. Dress for the day.
  • Beware of off-shore winds that make it difficult to return to shore.
  • Always follow the boating rules of the area you're in.
  • Never mix alcohol or drugs (prescription or non-prescription) with boating.
  • Never exceed the weight capacity of your boat and always check your equipment for wear and tear before you paddle.
  • Seek qualified instruction to learn proper paddling techniques, water safety and basic first aid.
  • Brush up on self-rescue first in calm, warm, shallow water, and again in more extreme conditions.
  • Tell someone your paddle plan, which includes: where you are going, what you will be doing, how long you expect to be gone and how many people are in your party. Then stick to your plan.
  • Paddling in the surf zone or in rivers can be dangerous. Always wear a helmet.
  • Stay hydrated. Always bring plenty of water and food.
To know more about a fishing kayak you can check here
Best Sit In Fishing Kayaks In depth Guide Reviews For 2018
May 24, 2018 • Boating
tip
Tips for Choosing A Best Fishing Kayak
Best Fishing kayaks come in all different shapes and sizes and it's important that you choose the right one. Because not only will it let you get the most enjoyment out of your time on the water, it'll make you safer on the water.
When choosing a fishing kayak, narrowing down your options is actually pretty easy, and it starts with identifying how and where you'll be using it:
• Will you be fishing small sheltered bodies of water like ponds and small lakes?
• Or will you be taking the kayak on big bodies of water that are exposed to wind and waves?
• What's the water temperature going to be like?
• And when it comes to performance, is it more important to have a kayak that's fast and responsive?
• Or are you more concerned about having a kayak that is stable and difficult to tip over?
With these questions in mind your first and biggest decision will be whether to get a sit-inside kayak or a sit-on-top kayak.
Sit-on-top kayaks are the most user friendly fishing kayaks. They're very stable and easy to get in and out of, and there's no feeling of confinement on them. They're also self bailing, which means the water drains through small holes called scupper holes. They go right through the bottom of the kayak. This means you can't swamp a sit-on-top kayak. Another great safety feature is that sit-on-tops are much easier than sit-insides to get back on to from the water, if for some reason you fall off. The one downside to sit-on-top kayaks is that you're almost guaranteed to get wet while paddling, while sit-inside kayaks allow you to stay dry.
Sit-inside kayaks can be a good option for anglers who will be in cooler water, who want to stay dry while paddling, and who want a faster moving kayak. Just keep in mind that if you flip a sit-inside kayak, recovery is not necessarily a simple process because the kayak may swamp. As you're learning, try to stay in sheltered water or close to shore so you can swim in if you need to.
Once you've decided on whether to go for a sit-inside or sit-on-top kayak, you'll need to decide on a length for your fishing kayak. As a general rule, a long and narrow kayak will be faster, while a short and wide kayak will be slower but more stable. If you are only going to be fly fishing and sight casting, a short, wide, and stable boat is a great choice because standing is easy. The trade-off is that the kayak will be pretty slow and not ideal for paddling any real distance. On the flip side, if you want to cover more ground or maybe even troll offshore, you might want to choose a longer, narrower kayak that travels through the water more efficiently.
Once you decided on the style and size of kayak, there's one more key decision to make: Do you want a pedal kayak or do you want a paddle kayak? Traditionally kayaks are powered by paddles, but there are a number of companies that now offer pedal kayaks. One of the benefits of pedal kayaks is that they leave your hands free for fishing. The downside is that they're less maneuverable and heavier than other kayaks. The pedal system also works less efficiently in really shallow water. If you do decide on a pedal kayak, something to keep in mind is that it's very important you have a good paddle on board as a backup.
At this point you dramatically reduce your options, and most of your decisions will now impact the comfort of your kayak, and relate to features of convenience for the type of kayak fishing you're going to do.
Best Fishing Kayaks For Anglers In 2018
on Feb 28, 2018 • Boating
What is the cheapest fishing kayak?
What Does Really Matter:
Stability
Speed
Durability
Maneuverability
Storage/Gear
Best Fishing Kayaks Under $400
Sun Dolphin Aruba SS Kayak
The spray deflectors allow you to take the kayak into fast river and lakes without running the risk that you get with an inflatable kayak. The large cockpit and adjustable foot braces allow for comfort and flexibility to get the most power from your paddle.
A large, comfortable seating part with protective thigh pads. Other facilities involve a P.A.C. (Portable Accessory Carrier) that can be used as a tow behind the storage; a hands-free electronic support; shock cord deck rigging and water bottle holder.
Sun Dolphin Aruba SS Kayak review help you what you need in a fishing kayak, and make a well-informed decision when buying.
  • Brand: Sun Dolphin
  • Overall Length: 10-feet (3.05m)
  • Overall Width: 2-feet 6-inch (76cm)
  • Product Dimensions: 11 x 30 x 120-inches
  • Item Weight: 40 lb.
Best Fishing Kayaks Under $300
Sevylor Fiji 2 person Inflatable kayak is an amazing watercraft that is perfect for beginners who want to learn the sport. Our Sevylor Fiji 2 Person Inflatable Kayak review will tell you what you can find in this best inflatable kayak for beginners. The Sevylor Fiji ships with a five-piece touring paddle and a travel bag.
This Sevylor Inflatable kayak is very lightweight and easily deflates to fit into the carrying bag for easy transport. So, it will be great if you take the Fiji with you during hiking and biking time, or on camping trips. However, this boat is designed for Class I and II water, and it is suitable for ocean surf and flat-water lakes.
  • Brand: Sevylor
  • Model: Fiji 2-person
  • Type: 2-person Inflatable Kayak
  • Size: 10 feet 4 inches
  • Dimension: 34.8 x 35.5 x 124.8 inches
  • Use: Recreational, Fishing (Lakes, Bays, Water bodies...)
  • Material: 22-gauge PVC construction
  • Weight: 23.8 lbs.
  • Weight Limit: 400 lbs.
  • Number of Chambers: Multiple air chambers
Apr 11, 2018 • Boating
What are the best places in Seattle to go kayaking?
Kayaking is the new canoeing and a fun family activity everyone can do at their own pace. But kayaks are expensive, so before you run out to buy one, consider renting one instead. At many spots, you can also sign-up to take guided nature tours or rent stand up paddle-boards. Sound like fun? Read on for a list of places where you can get the whole fam geared up and ready for some summertime paddling fun.
A Complete List of Top 4 Fishing Spot in USA
Fearless Florida
  • Best Place: Florida Keys
  • Fishes Found: Bonefish, Milkfish, Trout, Salmon, Redfish, and Snook
  • Preparation Needed: Kayak in the shore and boat in across the blue tide. Spinning reel for smaller prey and bait casting reel for fly fishing.
  • Other Places: Jacksonville, Banana River, St. Acquisition
  • OtherKayaking Information: You can enjoy fish barbeque from your game fish and also camp out in the wild with the help of the local organizations. These are very affordable and helpful.
Tough Texas
  • Best Place: Lake Texoma
  • Fishes Found: Trout, Salmon, King Salmon, Marlin
  • Preparation Needed: Kayak, with both spinning reel and baitcasting reel, motor with the kayak
  • Other Places: You can try out Caddo lake, Lake Amistad, Lake Fork
  • Other Kayaking Information: You can enjoy the lake beach in Caddo Lake after you get a bit tired of all the kayaking. There is also a nearby spa if you are in the mood for some refreshment.
Hot Hawaii
  • Best Place: Kona River
  • Fishes Found: Mahi-Mahi, Sharks, Tuna, Salmon, Puffer, Marlin
  • Preparation Needed: Motor kayak, large threaded spool, larger storage
  • Other Places: You can also check out the Buro-buro island and the Crystal Lake
  • Other Kayaking Information: There is a lot of different kayaking stores in Hawaii, and you can pick up different kinds of accessories from those at a very affordable rate.
N-Joy North Carolina
  • Best Place: Outer Banks
  • Fishes Found: Tuna, King Salmon, Flounder, Trout, Blue finned marlin, milkfish
  • Preparation Needed: Kayak, motors, hooks, fishing license
  • Other Places: You can also try out nearby places of Outer Banks. Most of them offer a wide variety of fishing tools at an affordable price. Plus, you can also go to the water aquarium nearby.
  • Other Kayaking Information: It would be better if you always carry a motor and a large container on your way. Cause the water might get rough at times, and you might end up in a bit of trouble.
Apr 09, 2018 • Boating
2answers
Is a canoe or kayak better for fishing?
Obviously, for fishing, a kayak is very much suitable. there are many types of a kayak, Fishing kayak is one of them. A fishing Kayak helps you find more fish. fishing kayak is made with fishing facilities. If you used a kayak for fishing you will be surprised that how fishing will be easy. You can go with kayak in river or ocean and it's easy to control a kayak. If you want to know more about kayak you may check the ink bellow Best Fishing Kayak Under 600 in 2018 Recommended By Experts
Mar 28, 2018 • Boating
What would cause water to leak into the upper partof a 1992 evinrude 48spl outboard boat motor
I Presume You Are Talking About Water In The Combustion Chamber.
If So The Head Gaskets Or Water Jacket Gaskets Are Corroded By The Salt Water.
Replace Gaskets.
2answers
Is this kayak very stable in the ocean
Hwello
I read all the reviews of the boat I could find, all were VERY positive, all said the boat was very stable in all water conditions, the only draw back comment I ran across is that it is fairly heavy, but that is due to its rugged design, so really you can't have it both ways.
Having Kayaked in the Ocean many time myself I would buy this boat for that purpose after what I read. Here are some transcripts of the reviews I read
"used one of these while on vacation in canada,and i'm hooked it was very sable on rough waters,and we also took it out and went fishing ."
Bottom Line Yes, I would recommend this to a friend
"The Future Beach Freedom 160 is a nice stable boat with a rugged and durable build. Due to it's weight the boat is a bit on the slow side and a challenge to move around. Storage at the front of the boat is limited but could be expanded with a small modification. I am sure that this would be a great boat for fishing and other water sports (i.e. snorkling, SCUBA)."
"Love this boat, Amazing Quality, superb tracking
An absolute pleasure to use !!!!!!!!"
Top NRS Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a NRS Boating Expert? Answer questions, earn points and help others
