Byd:sign HDTV screen goes black but the volume stays on. the screen worked perfectly till last night when it started cutting off. once the TV is turned off for a few minutes and then turned back on the screen will work again but only for a couple of minutes.
This unit should still be under warranty and should be taken in for warranty service. Any attempt to access the interior will void the warranty. It is important that a complete description of the problem like you entered here be taken along when you bring the set in for service. This will insure that the servicer be able to reproduce the problem and resolve it.
From your description (and as a servicer), I would be looking for a component that is heat sensitive. These types of problems are fairly easy to locate and resolve.
Please take this in for warranty service and update this when you find out the details.
try changing the resolution settings on the ps3 itself to match your tv because if the tv cant handle 1080p then dont set it to it, going into a game changes the resolution to mach the games rated one
I had the same thing happen to me this morning. I turned on the TV and it had colored vertical lines through the whole screen. I called Sony and they had me unplug the TV for about 15 minutes. This solved the problem. They said the boards just needed to be reset. It fixed the problem and I am happy with my Sony once again.
