Tomtom XL 340S Car GPS Receiver Logo
Posted on Oct 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i try to backup to my computer: Following Error Occurred: ERROR: DesktopLib/FileCopy/Error: An error occurred. Unable to create the files required to copy this item to your computer. @ .controllerFileCopyThread.cpp(137) An error occurred while reading this file: "H:LoquendoTTSdata oicesSusanSusanGildedPhrases.16000.LTTS7CodecMsx.32800.10.bin" An error occurred while writing to this file: "C:Documents and SettingsHeyManMy DocumentsTomTomHOMEBackupONE XLBackup01InternalMemoryLoquendoTTSdata oicesSusanSusanGildedPhrases.16000.LTTS7CodecMsx.32800.10.bin" in .controllerFileCopyThread.cpp:137 Stack: 0. chrome://tthome/content/ui/bindings/commit.js:82 error(textOrException); 1. chrome://tthome/content/ui/bindings/ttwizard.xml:1058 this._commitFailed(i, commitPage); 2. chrome://tthome/content/logic/util.js:79 return func.apply(obj, arguments); 3. chrome://tthome/content/logic/dllUtils.js:77 this._errorCallback(e); 4. chrome://tthome/content/logic/dllUtils.js:69 this._errorFatal(error); Time: Mon, 19 Oct 2009 01:13:58 GMT This device doesn't work anymore Doesn't show any menus
JEfromCanada
Level 2:
Scholar:
  • Expert 59 Answers
  • Posted on Dec 02, 2009
JEfromCanada
Expert
Level 2:
Scholar:
Answers
59
Questions
0
Helped
31477
Points
124
When TomTom Home installs, I believe it either also installs, or needs to have installed, a copy of the Visual Studio Runtime (a 'C' language runtime from Microsoft). Also, your computer needs to have JavaScript enabled in the browser.
Check to see that both these required items are installed. It is beyond the scope of this question to tell you how to do that, I'm sorry.
How to Fix QuickBooks Error Code C=343?
QuickBooks Error Code C=343 can occur when there is an issue with the data file used by QuickBooks. To fix this error, you can try the following troubleshooting steps:
Close QuickBooks and all other programs running on your computer.
Repair the data file by following these steps:
Open QuickBooks and go to the File menu.
Select "Utilities" and then click on "Verify Data."
If QuickBooks detects any problems with the data file, it will prompt you to repair it. Click on "Repair" to start the repair process.
If the error persists after repairing the data file, you may need to restore a recent backup of the data file.
If the error continues to occur, you can try repairing or reinstalling QuickBooks to see if that fixes the problem.
If none of these steps resolve the error, you may need to contact QuickBooks support for further assistance. They may be able to identify the specific cause of the error and provide additional troubleshooting steps.
It is also a good idea to regularly create backups of your QuickBooks data file to prevent data loss in case of errors or other issues. This can help ensure that you have a recent copy of your data that you can use to restore your file if necessary.
12helpful
3answers
Toshiba satelite error message0xc00000e9. how do I fix it?
Error Code: 0xC00000E9
Error Translation:BERR_DUPLICATE_PROXY
Problem: Unable to process object %1 because the specified e-mail address %2 has the same type as one or more other e-mail addresses specified for the same object.
#define BERR_DUPLICATE_PROXY 0xC00000E9L
Source: Microsoft Support
solution:
Restart the laptop, and then press F8 to enter the Windows Advanced Options Menu, and select Safe Mode,
then fix your email address
When turned on it would go to screen saying "A disk read error occurred, Press ctrl+alt+del to restart"..It would do nothing else..so following instructions from the internet i tried to restore it to...
The hard disk is defective and must be replaced. Only then you should reinstall, using the backup disks that you must have created before that. If you don't have the restore disk you must order it from them, and unfortunately pay for it.
Turbotax 2008
Hello There, I found this in their FAQ Guide. Hope this resolves your problems, I know it is a bit of a read. Good Luck!!
What is happening?
Double-clicking on a backup, portable company file, or a file with an extension other than .qbw, the following error occurs:
An error occurred when QuickBooks tried to create, open, or use the company file. Please try again. If the problem persists, contact Intuit Technical Support and provide them with the following error codes: (-6150,-1006).
Or, if you attempt to double-click the data file without QuickBooks open, the following error occurs:
There was an unexpected error reported while trying to run QuickBooks with company file "path location". Error code 80070057.
Note: More than one error message that includes the error code 80070057 exists. If this is not the exact wording of your error message please refer to one of these other documents:
Error: 80070057 parameter is incorrect" when clicking on a QBB, QBM, QBW, NT, or TLG file from a Google Search Timeline
Error: 80070057 parameter is incorrect" when clicking on a QBB, QBM, NT, or TLG file from a Google Search Timeline
Error: 80070057, the parameter is incorrect. There was an unexpected error reported while trying to run QuickBooks with company file [path and name]
Error: 80070057 the parameter is incorrect" and "You do not have sufficient permissions to delete files...
If your Error 80070057 is different than the ones displayed, perform a new Search.
Why is this happening:
QuickBooks cannot read the company file because the QuickBooks file extension was changed or is the wrong type (.qbm, .qbb, .qbx).
This error can also occur during conversion or creation of a backup or portable company file if QuickBooks detects data damage in the company file.
This error may possibly occur if the QuickBooks installation is damaged.
This error can also be caused by attempting to open the portable company file (.qbm) without having QuickBooks open.
How to fix the problem:
Verify that the file extension displays company name.qbw and not a shortcut.
Copy the company file, change the extension to .qbm, .qbb, or .qbx, and follow the appropriate steps to open a portable file, backup, or accountant's review.
If the error occurs during the conversion or creation of a backup or portable company file, run the Verify utility to check the file for data damage. If it finds damage, run the Rebuild utility.
Repair the QuickBooks installation.
Uninstall, and then reinstall QuickBooks.
2answers
Constantly getting write data to media errors
If you're using the MS Backup utility, it's creating .BKF files which are very large (1-2GB+). Your external hard drive uses a FAT32 file system, which has a limitation of 4GB per file. If your backup files are over 4GB, it won't copy. It probably worked on your 250GB hard drive because it was formated with NTFS and not FAT32. You'll need to limit the size of your backup files to 4GB or less, or use a different utility that has file-size splitting options.
1helpful
2answers
Tom Tom 720 won't back up and falters during operations
You have to make a manual back up of the device. Make a new folder on your desk top. Connect your device to your PC and turn it on. Go to my computer and look for tom tom storage device and open it. You will see all the folders that is in your tom tom. Copy and paste just the yellow ones into the new folder. When you have done this you can know reformat your device. Do this by right clicking on the tom tom logo (in my computer). Click fat 32 (full format). This will wipe everything off. Disconnect your device, you will see a red cross on the screen. reset the device with a paper clip (hold in for 30 sec) You will still see the red cross. connect back up to PC and install the latest application of to tom home on to the device. From here you can go to add maps ect, and put your maps back on the device. Tom tom home will give you all the updates your device will be missing. You will only need the maps so don't worry if you can not copy all folders (for whatever reason) you can get everything you need as well as free updates for free via tom tom home. Its only the maps you have to pay for.
A window appears with the following message. Time Machine Error Unable to complete backup. An error occurred while copying files to the backup volume.
It appears to be a scheduled backup task not being completed.
You can disable the task by going to the backup software and removing the backup schedule.
I can't tell you the exact procedure since i don't know anything about your system.
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
