you put a small long pin in to the holl which you can see just below the door and push to the lever so that the door lock will open, then you check and replaced the rubber belt if required
I've had some luck with unplugging the DVD player, plugging it back in, and then pushing stop on the DVD player and then open. See if that works. Sometimes it just locks up like a computer.
Look at the door of the player. There should be a small hole on the door. stick the end of a paper clip into the hole and that should release the door. Kind of how you would open a locked bedroom door lock.
Sound like it either has one or two problems, the door is stuck and or the door eject motor has failed. Look in the front to the player for a small paperclip like hole, and use a paper clip to manual eject the and engage the loading mechanism usually located under the door for most cases. Check you manuals troubleshooting section for manually ejecting a CD..
The Disc Tray Will Not Open And/Or There Is A Disc Stuck In The Player.Some DVD Players manufactured prior to 2003 have a Dealer Lock or Child Lock function. This will prevent the panel buttons from operating.
This function is activated by pressing the STOP button on the front panel and the POWER button on the remote control simultaneously for four seconds in the power on state. Repeating this sequence releases the dealer lock. When the dealer lock in activated, DEALER LOCK ON or DEALER LOCK OFF scrolls on the display.
If this does not resolve your problem there may be an error with in the player. To resolve this try the following these steps:
Unplug the DVD player from the electrical outlet and leave it unplugged for thirty seconds.
Plug the DVD player back in to the electrical outlet, but do not turn the DVD player on.
With the DVD player off, press the [Open/Close] button on the front of the DVD player. The home theater should power on when you press the [Open/Close] button and eject the tray.
