Motorola Mobility RAZR V3 Logo
Posted on Dec 29, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Motorola razr 1.3 mp cell phone
I want to change my personalanswering message to the automated answering message. I can't find where or what to change to change the answering message.
Anonymous
Level 3:
Brigadier General:
  • Master 7,752 Answers
  • Posted on Dec 29, 2007
Anonymous
Master
Level 3:
Brigadier General:
Answers
7752
Questions
Helped
1416135
Points
13016
Press and hold down the number 1 digit button on the phone's keypad and it will automatically open to the vm msg center....just follow the step by step instructions and that will get you thru
A
Anonymous
I just figured that out and came back to send this to everyone. It does not tell in the manual. I read it from cover to cover. I knew I had to find how i did it when i recorded my personel message. Thank you for all the help though.
How do I remove the battery for a Droid RAZR M phone?
Hi
The Droid RAZR M is a non-removable battery device.And if you try to remove it, it is consider physical damage.
Please contact us to check your repair options.
Motorola Support Find Answers Motorola Mobility Inc
Regards
Marge
Motorola Mobility
1helpful
Change a Motorola V3 RAZR cell phone from T-Mobile to A.T.&T.
If your phone is lock to a single network, the answer is "NO", but if it is open line , then YES you can
I have a Motorola V3i and would like to change the answer message to something different how do i do it.Many thanks
go to personalise ur phone in settings, then to ring styles, change detail, u av a list ie ring volume , calls etc look for messages , click change then select ur tune etc hope this is what u wanted ta
Keypad not working during phone call
u'll have to get the keypad checked ...because the connection b/w the buttons and the chipset does seem to be ok.
How to set up greeting w/o automated instructions & options
not possible that is a built-in feature on the phone
2answers
Voicemail answering
Contact your mobile service provider's helpdesk for further assistance on activating your VM
Recorded message after my personalized greeting
This isn't in the phone. It's in your voicemail preferences. Listen to all options in your voicemail settings. Just keep listening for an option number for settings after it tells you that you do or dont have messages. If you dont find something fairly obvious call *611 and tech support should be able to talk you through it. Call from a phone other than the razr.
Text messaging
Hi ur problem is very simple. u go ur nearest motocare centre and change ur 's mobile internal keypad.
17helpful
4answers
If sounds like DTMF is turned off on your phone. If it is then it is not sending the correct tone over the air which is why nothing happens. Go into setting, then to initial setup and key down toward the bottom and you should see DTMF if it is off change it to short or long and that should correct you problem.
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
