Question about Bunn BTX-B ThermoFresh 10-Cup Home Thermal Carafe Coffee Brewer, Black
Bunn thermofresh makes very weak coffee , water comes out hot, goes through grounds.. but even with double strength , it is very very weak, we changed filters, added even more coffee and its still weak.. resorted to our 4 cup Krups with same coffee,, perfect coffee
    New Friend:
I don't know what the flow restrictor looks like, but I know what a spray head looks like.
My new Bunn BTX-B brewed weak coffee also. I was wasting coffee to get it stronger. I decided to inspect the spray head. What The hey! What Spray Head? The coffee maker didn't even have one. I guess the assembler forgot to put it on. Yet it made it thru quality control. No wonder it was making weak coffee, and I was wasting coffee to try get it stronger.
Is your making weak coffee? CHECK YOUR SPRAY HEAD. Make sure the coffee maker has one on it.
Posted on Dec 02, 2012
    Problem Solver:
  • 8 Answers
I work 4 BUNN and we have a flow restrictor sprayhead that might help. If you send me your address we can send one out to you.
Posted on Oct 21, 2009
  • 1 more comment
  • higgins4_3
    higgins4_3 Jan 03, 2012
    Mine is very weak as well.
  • Doug Apr 07, 2012
    I received that "flow restrictor" and I still need to add too much coffee for flavor. Wasting coffee, here, because the grounds can't steep in this one. When buying this machine, I was under the impression that Bunn machines were made by connoisseurs. This one was obviously not tested before marketing, or Bunn engineers aren't coffee drinkers. Thanks for the "restrictor."
  • Diane Giberson Apr 04, 2017
    I sent for the flow restrictor and same thing, weak coffee, I tried 4 or 5 different brands, I even bought beans and ground them myself, and even when I added more than half a cup of coffee grounds to brew it was still weak. I resorted back to my $8.00 5 cup Mainstay coffee maker at Walmart that I had bought for when traveling and it brews a 100% better cup of coffee than my $100.00 Bunn. My Bunn is in the closet and after spending 100.00 on a Bunn, I have an $8.00 coffee maker on my quartz counter, it looks so cheap but makes a good cup of coffee.
SOURCE:
Why my bunn thermofresh coffee maker makes cold coffee
time for a replacement . they do not sell heating elements
Oct 31, 2016 | Bunn Coffee Makers & Espresso Machines
Water leaking from my Bunn ThermoFresh
if it is under warranty contact bunn directly , if not throw it away . they are not fixable
Feb 12, 2014 | Bunn BTX-B ThermoFresh 10-Cup Home Thermal...
We have a Bunn thermofresh coffee maker and I use it about 2 times a week. I have lost the instructions and am having a problem. I remember I am suppose to to put a thermo pot of cold water into the...
Are you leaving the machine on all the time? If not, you need to turn it on and leave on for 15 minutes before brewing a pot of coffee. If you will get the model and date# from the bottom of the brewer and give us a call we will be happy to assist you with this.
Oct 27, 2010 | Bunn NHB Coffee Maker
Coffee brewing comes out in a fast steady stream when brewing, coffee doesn't brew properly and comes out weak. taste like unbrewed.
If it comes out in a steady "stream" it sounds like the sprayhead is missing. The sprayhead disperses the water out and evenly over the grounds.
If the sprayhead IS in place then it could be a temperature problem. If the temperature is not hot enough the coffee will not brew correctly.
Sep 06, 2010 | Bunn Coffee Makers & Espresso Machines
My Bunn Coffee maker has one solid stream of water running from the nozzle. It goes straight down through the filter. The coffee is weak. Isn't the nozzle suppose to spay? I thought about using a...
I work for BUNN. It sounds like your sprayhead is missing because it should definitely be spraying versus flowing. We will send you out a free sprayhead - please call our customer service department at 1800 - 352-2866 with your model and will send it right out to you.
Feb 01, 2010 | Bunn GR10 Coffee Maker
Our Bunn, Tim Hortons coffee maker was making good coffee, but now, is making weak coffee, despite the fact we are still using the same quantities of coffee and water...
The little sprinkler in the grounds basket fell off and you probably accidentally threw it out. It splits the hot water stream into three streams. I just emailed bunn and they sent me one for free.
Jan 11, 2010 | Coffee Makers & Espresso Machines
My bunn thermofresh coffee pot will no longer keep the coffee hot. I always put hot water in the pot for up to five minutes to heat it up. This still doesnt help.
Is the coffee coming out hot enough? If you measure the coffee as it comes into the carafe, it should register at 175-185 degrees. If it doesn't, then it is a problem with the machine and needs to be replaced. If it is that temperature, then the carafe needs to be replaced. Please contact customer service with the model and date code located on the bottom of the machine. If the machine is 3 years or less it can be replaced at no cost. If over 3 years, it can be replaced at a reduced cost.
Nov 29, 2009 | Bunn B10 Coffee Maker
Coffee is weak
Check where the water comes out under the brew filter. It sounds like you may be missing the sprayhead. It is a round metal or plastic piece that is screwed on to the water dispense area and acts like a little showerhead forcing water evenly over the coffee grounds. If it is missing, the coffee will be weak. Check the water temperature. If it isn't hot enough, the coffee will be weak.
Jul 11, 2008 | Bloomfield 8571 Coffee Maker
Coffee is weak and watery
After reviewing troubleshooting diagrams, I really couldn't find a solution to your problem.
The only thing I can suggest is to use 2 oz per pot of coffee grounds. Your 5 or 6 scoops assuming they are one ounce each is way more than enough.
Look under where your basket goes. Most bunn coffee maker has a flavor guard on the downspout. this down spout actually helps distributes the water over the whole basket of coffee grounds. Most of the time I see these missing, and when they are gone, they are gone.
Use less water for the amount of coffee you are using first. Sadly when there is not enough water, the coffee tastes bitter. Too much water tastes weak. Hot water extracts certain elements out of the beans even after grinding.
Always use a fresh paperfilter designed for your coffee maker.
If this pot is not work correctly still, I will suggest seeing your appliance repair technician.
May 26, 2008 | Bunn BT10B Coffee Maker
Coffee Makers & Espresso Machines Logo
1,317 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Inky Fingers
Inky Fingers
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
