Archos Internet Media Tablet MP3 Player Logo
Posted on Oct 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I connect my archos 5 internet tablet with android to my vista computer it says its installing the drivers then fail it will say MTP Device failed
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Feb 19, 2011
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2469721
Points
19564
How do I connect my Android Tablet to my Laptop ?
1. Connect the supplied USB cable to the ARCHOS.
2. Plug the USB end of the cable into your computer.
3. The ARCHOS will turn on and ask you if you want to connect it (Mount) or not. Choose to Mount it.
4. If you choose to just let it charge, you can always drag the top notification bar downwards to reveal the USB notification message and choose to connect.
5. The ARCHOS will appear in your computer's file browser as an external hard drive, ARCHOS (E:) for example.
More Information & Instructions about your Archos 28 here:
http://www.archos.com/manuals/A32_EN_v1.1.htm#zzee_link_1_1294043188
2helpful
How to Itunes song onto the Archos 28.
You can connect you Archos to you computer by the USB cable which have came along with the tablet.
From tablet you need to choose mass storage device when you connect the cable. Once Mass storage activated you will see your tablet or SD card on your computer. You can copy paste or drag and drop songs from your computer folder to archos tablet Music or Media folder.
Or
You can use various Sync application from Android Market. Below given link is to list of applications available on Market. Please read description before you purchase or install any application.
https://market.android.com/search?q=itune&so=1&c=apps
Can get my archos 5 to conect to my android phone
If you mean to connect your Archos to your Android device through Wi-Fi, than, yes, you can! But, only if your android device supports the tethering feature. For example if you have an Android 2.2 (Froyo) device than you go to Settings->>Wireless & networks->>Tethering & portable hotspot and tap "Portable Wi-Fi hotspot". From the Archos, go to the the Wi-Fi settings and connect to the network you've just created. If you do not have the tethering option available, you should find out if your carrier or device manufacturer has an update for the device. Hope it helps!
My archos vision 1 is not recognised by computer
Hi, archos vision 1 player not recognized by the computer
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see archos vision 1 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the archos vision 1 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: archos vision 1 Players can connect to your computer in MSC or MTP mode. Exceptions are archos vision 1 Connect and archos vision 1 Express which only use MTP mode. MTP mode is the recommended and default method for archos vision 1 Players when used with Windows OS.
The archos vision 1 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Have a nice day....
2answers
I have a nook app on desktop on my laptop; was given an archos 101, I connected the USB cable to laptop & archos, dragged nook app to USB, but nothing show on the android
first you will need to go to Settings > applications > and then checkmark unknown sources. Then you will have to go to your file manager (like astro) and click on the .apk. The android installer will run and install the app.
Hi Just got my new archos 101 8gb Spec said 2.2 but it came with2.0.54. on plugging in to PC the upgrade didnt happen so upgraded to 2.1.04 Everything that I have thrown at it works but I dont have...
Betty,
Archos has been saying Flash would be officially available for some time now, but it's still not out. There is a beta version that I'm using, works great for me:
First step to getting Flash working is to go to your settings menu, then Applications, then check the box to allow for Unknown Sources to be installed.
To get a Beta version of Flash working use this link (from your Archos tablet):
http://ge.tt/36fA44X
You should be prompted to install this APK file on your Archos 101 after it's downloaded, this will give you a decent version of Flash (it's taken from a Droid X which has similar hardware to the Archos 101).
The Version number of your Archos 101 firmware is different from the Android Operating System. Version 2.1.8 is the latest Archos firmware as of Feb 28, 2011, this is Android 2.2.1.
To force an update, you actually need to connect the Archos 101 to the internet, not to a PC. Once you're connected to a Wifi network and have access to the internet, go to your Settings, then scroll to the bottom to About Device. On this screen is a Firmware Update option, this will check for and download the latest. Once it's downloaded you'll be prompted to plug your tablet into the charger and restart it to apply the firmware.
6helpful
Skype for archos
you can get skype for Android here http://www.freeware4android.net/archos-28-internet-tablet-4gb-8gb-device-1663/skype-android-download-17736.html
10helpful
Reinstalling flash player on archos 5
you will most likely have to wait on the release from adobe in october for that to happen.. in the mean time you can install the google market on the archos and then install opera mini web browser and it will allow you to watch youtube videos.. i found that to work best for me.. opera mini can only be found in the google market for android download though.. i tried several times to find it before but i never was able to get a download link for android...
hope this helps... Daniel
1helpful
The archos 5 won't connect to the computer with the usb.
Ijust bought a archos 5 250gb , conected via usb and drag some music from pc to archos . A few hours late the archos stopped, the pc don´t recognize the archos .
I pressed the on/off and vol together and formated the aarchos .
now had been disaster , the display just appeared the ARCOS Entertainement you way . the pc don´t regognizer the ARCHOS, NOTHING APPEARED .
Top Archos Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
