LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer - White Logo
Posted on Oct 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our LG model WM2032HW intermittently show up with th FE code what could be wrong and can it be fixed by us?
Anonymous
Level 3:
President:
  • Master 632 Answers
  • Posted on Oct 19, 2009
Anonymous
Master
Level 3:
President:
Answers
632
Questions
0
Helped
276387
Points
2196
FE error code means water is overflowing. The water is over 8 level.When FE is displayed, the drain pump will operate to drain water automatically. Otherwise the pressure switch assembly is malfunctioning. Check and replace if necessary. Part number is 6600FA1704X.
The pressure switch assembly shuts off the water inlet valve when the desired water level is reached. It then activates the drain pump when the water inlet valve is not deactivated.
I replaced the filter on my LG dishwasher, model LDS 5040ST and after attempting to run it Igot an FE code?
FE means FILL ERROR. Usually cleaning the floats will fix this issue. Just follow the instructions from the video.
I have an lg front load washer model # wm2277hw/01. The error code looks like an upside down FE. The manual doesn't show a possible cause but to unplug machine and call for service. Any ideas on what the...
I think the only way forward is to call for a quote as theses days they always put a service program in the machine circuity to enable them to warrant a service from them alone as we mortals have to pay for it, or the display unit is giving the wrong information it could have become faulty normally only the Russians language is written backwards in places eric
1helpful
"PE errors lg washer wm2032hw" I replaced the
Check the condition of the tube as any small crack or hole will render the pressure switch useless.
If in doubt replace the tube.
1helpful
I have an LG Senseclean and th FE code was showing and water level was higher than normal. Now PE code is showing and washer wont function at all?
LG's 'FE' stands for 'overFlow Error' (or Flood Error is how I remember it!) and 'PE' for '(water) Pressure Error'.
So- looks like you have a leak which has been detected by the sensor in the flood detection tray underneath which is there for exactly that purpose, sorry.
Service call ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
2answers
I am getting fe error after the water fills in.it doesnt start washing. What to do?
The FE error isn't common to all washers. In fact, I could only find information on it in relation to LG washers. I actually found this link here which explains it pretty well:
http://www.managemylife.com/mmh/questions/208013-lg-wm2032hw-error-fe
1helpful
LG WM2032HW spin cycle
I had the same problem. You most likely have a drain pump issue. For me, after getting to the drain pump, I found that the hoses leading into it were clogged with dirt. I cleaned all the hoses, and took off the drain pump itself. The impeller (the little plastic blades inside) had come off the pump shaft. I was able to clean out the impeller and pump housing and it went back on. You'll know it's all the way on because it will click into place and then it won't easilty (if at all) pull back off. After this cleaning, mine worked fine. Hope this helps.
4helpful
2answers
Lg wm2032hw
check the pump filter and if necessary clean it up.
if you stop the programme and hold the start/ pause button for 3-5 sec the programme will cancelled and the drain will work.
if you hear a slow noise from the pump it may be blocked with external objects from your clouthes pocket,
so you need to contact a repairman.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
