Thats very easy first unplug the stove lift the top it should stay up with the arms extended,pull the arms out of the slot and remove oven top , gently pull knobs off , remove all hidden screws behind knobs, remove the front panel held in place by 2-3 screws on top and under panel, remove 2 screws holding existing thermostat unplug 2 wire thermost follow capillary to sensing bulb which is inside the oven unless it broke off it should be there, im asuming thats why you are replacing it ,remove sensing bulb from 2 brackets holding it in place make sure its perfectly straight because it has to pass through a small hole, installaton is the opposite of removal good luck.
