Disney Hannah Montana DVD Player Logo
Posted on Oct 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bought it from usa cant get the dvd player to play dvds my daughter has it keeps saying wrong region .how do i fix this.
  • christine650 Oct 20, 2009
    thanks tried it just keeps spinning the discs and says wrong region.the hannah montana tv sits on top of the dvd player the two go together and you hava two remotes the tv one only has numbers you can use will this work the same .the two are linked with the differnt coloured connection cables.tv works fine bought it here in uk.do you know of any other way of fixing this help would be appreciated. thank you from christine.
Anonymous
Level 2:
  • Expert 189 Answers
  • Posted on Oct 18, 2009
Anonymous
Expert
Level 2:
Answers
189
Questions
Helped
62964
Points
580
HELLO
With this unit being from America its probably LOCKED to Region 1 and this means you can only play discs from USA, Canada the US territories and Bermuda. Any other discs will simply not play.
You need what is known as a Region Hack which can usually be done from the remote control handset. However, there are machines out there which CANNOT be hacked via the remote.
I have found this hack, it may work for your machine or it may not!
Power on
Open disc tray
Press stop
(or there may be a button marked CLEAR)
Press 1 3 6 9 0 (the zero being for multi-region play back)
Close disc tray
Power off
Good luck with it (:-)
  • Anonymous Oct 21, 2009
    HELLO CHRISTINE
    If can post the actual make & model number on here I will try and do some searches on the net to help you out.
    HELLO AGAIN CHRISTINE
    I would like you to try the hack I gave you again (don't use stop key) use the CLEAR key. Always use the remote supplied with the DVD unit. I have had a good look on the net and I don't think there is an easy answer. Try it again anyway.
    The main DVD screen looks just like the one on a Pacific DVD player and the hack I have supplied you with is for a PACIFIC player. Let me know what happens and I will try to sort something else. (:-)
    Tony.
My Samsung smart tv & my dvd/bluray player recorder I bought at same time. Haven't had blurays til now & wont play at all. Rental ones did now I've bought my own & they don't play!Not tech minded.HELP
Each DVD player is assigned a code for the region in which it's sold. For example USA/Canada are Region 1 players. DVD players will refuse to play discs not coded for its specific region. In effect, this means that a DVD purchased in one country is normally unreadable on a DVD player bought in another region.
If your rental DVDs work in the player then there is nothing wrong with your DVD player. If you have purchased DVDs that do not work the problem is with the DVDs you have, not with the DVD player.
2answers
Wrong region
probably you are trying to play a disc that is not zone free or you need a code for your player to make it zone free. you may be playing a zone 2 disc ( PAL) on a machine that only takes zone 1 (NTSC) or vica-versa.
2answers
Blaupunkt tv dvd combi saying wrong region
NTSC/PAL/SECAM Color System
Europe used PAL/SECAM format, check settings on tv
2answers
I have recently bought a DVD that says it only works in a region 1 DVD player and the people who sold it to me said that I could change my DVD player to play this DVD, I was wondering if this information...
IF YOU LIVE IN THE USA OR CANADA THEN YOUR IN REGION 1 AND IT WILL PLAY WITHOUT CHANGING ANYTHING BUT IF YOU LIVE IN ANOTHER REGION OR YOUR DVD PLAYER IS FROM ANOTHER COUNTRY FOR SOME REASON THEN IT WONT PLAY.ALL DVDs MADE IN THE USA OR CANADA ARE REGION 1.
Hi i have bought a dvd and comes up saying wrong region how can i fix this
DVD players usually are locked to a Region code and cannot play DVDs from other regions unless the DVD player has its firmware changed to Region Free.
To change your DVD player to Region Free, please check out these WEB sites :-
Unlock DVD Players - Region Free Code www.dvdexploder.com/
www.download-info.com/dvd/index_new.htm
2answers
Trying to play dvd but says wrong region soneynhv-dx350ab?
Hi, if its saying wrong region. then either your player or disk is incompatable. region 1 ntsc ( USA ) Region 2 ( UK ) et,c. check your players region coding is compatable for your country, and that you are also playing a dvd with the same region coding as the player. alternatively is to try and find a region free or multi-region solution. Mike @ Compurepair.
Hi i was after a no region code for a dvd player!!!
To unlock the DVD code its defends upon what region you belongs or from were you bought the DVD unit. Just click this site to hack the region code ; http://www.videohelp.com/dvdhacks
To keep it simple, this means that DVD players and DVDs are labeled for operation on within a specific geographical region in the world. For example, the U.S. is in region 1. This means that all DVD players sold in the U.S. are made to region 1 specifications. As a result, region 1 players can only play region 1 discs. That's right, the DVDs themselves are encoded for a specific region. On the back of each DVD package, you will a find a region number (1 thru 6).
The geographical regions are as follows:
REGION 1 -- USA, Canada
REGION 2 -- Japan, Europe, South Africa, Middle East, Greenland
REGION 3 -- S.Korea, Taiwan, Hong Kong, Parts of South East Asia
REGION 4 -- Australia, New Zealand, Latin America (including Mexico)
REGION 5 -- Eastern Europe, Russia, India, Africa
REGION 6 -- China
REGION 7 -- Reserved for Unspecified Special Use
REGION 8 -- Reserved for Cruise Ships, Airlines, etc...
REGION 0 or REGION ALL -- Discs are uncoded and can be played Worldwide, however, PAL discs must be played in a PAL-compatible unit and NTSC discs must be played in an NTSC-compatible unit.
The end result is that DVDs encoded for regions other than Region 1 cannot be played on a region 1 DVD player, also, players marketed for other regions cannot play region 1-stamped DVDs
Hope it may help you;
Regards;
VOTIT
2helpful
2answers
GPX portable DVD model PD808B - wrong region message
Turn on power. Open lid. Enter 9735 with the remote and press 'enter', you can now choose between regions on the screen. Select the desired region unlock and press 'enter'. This works well!
Benony Jonsson
2answers
Cant play region 1 dvd set for region 2
what you need is the region code for your dvd player. so you can play region one and any other region dvds. what is the brand and model of your dvd player? then i can check and see if there is a hacking code for you.
tom
1helpful
2answers
Wrong Regional Disc.
DVDs are ecoded with region codes to indicate what area of the world they are made for. These codes may be 1,2,3, etc depending on which region they are made for.
DVD player read these codes and if the disc region code does not match the region the device is made for, the player will not play the disc.
Region 1 is for USA so most DVDp players made for use in USA require region 1 discs.
Some DVD players called multi region DVD players can be set to play different region DVDs but they are typically more expr=ensive then one region players and the code must be changed each time a different region disc is played.
Top Disney Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
