Apple iBook G4 Mac Notebook Logo
Anonymous Posted on Oct 18, 2009
While I was on the internet my ibook g4 locked up. I tried to restart but it continued to lock up. I tried to reinstall OS10 but the computer locked up in the middle of the install. I have replaced the memory card and hard drive with the same results. What else could be wrong? Logic board? I am lost here.
Anonymous
Level 2:
  • Apple Expert 481 Answers
  • Posted on Oct 28, 2009
Anonymous
Apple Expert
Level 2:
Answers
481
Questions
Helped
175749
Points
801
If by "lock up" you mean the mouse/keyboard freezes and the machine becomes unresponsive to any input, and you have already replaced the memory with a known good memory, you may have a logic board problem (not necessarily, but quite possible).
First place to start is by running the Apple Hardware Test from the DVD that came with your unit. (The test is specific to each model of Mac, so don't try to run it off someone else's DVDs unless they have the same model you do.) If you no longer have these, an Apple-Certified Macintosh Technician will have a special Apple DVD containing the collected tests for all models of Mac.
I have a grey screen and apple on my iBook G4. No cd and I don;t know where to turn.
if you or a friend have another Mac, use it to start up the iBook in Firewire mode (hold the T key on the laptop when restarting). You can reinstall the operating system, or try to simply repair the disk with Disk Utility.
If you need further help, reach me via phone at https://www.6ya.com/expert/john_77bb351c0c06b354
When i try to boot my ibook G4, a grey screen comes up and then it states "you need to restart your......" in different languages, I tried to reboot in safe mode: by pressing down the "shift" key and...
that's a kernel panic, which means there's probably a problem with your operating system. Use the original disks to reinstall the OS.
When I turn on the mac iBook G4 it says you need to restart the computer, and when I did it just gives me a black screen and it chimes but nothing else.
Try SMC and PRAM reset. To do this you need to google the model number and the reset instructions. If that does not work you need to reinstall the OSX
While is was searching on the internet my iBook G4 locked up. I tried to reboot and it locked up again. I tried to reinstall OSX but during the install it locked up. I replaced the memory and hard drive...
Dude, if you have all the current updates for your OS and applications, then you got a logic board issue. Especially if you you keep seeing the spinning beach ball of death or the dreaded white screen of death.
The iBook G4 is the poster child for logic board defects, because it has to do with the way the circuit boards were flowed.  Apple won't fix this for the iBook G4.  You got to do a big class action lawsuit like they did with the iBook G3 before they will replace the logic board.
Best bet is to sell this thing on e-bay as a non-working unit and get you a better laptop.
Not able to install system software
Leopard is not really suited for the iBook G4.  I would recommend you go back to Tiger and see if that gets rid of your lockup.  Leopard is more suitable for the Macbook.
2answers
I recently bought a IBook for $10 at a yard sale. I knew the previous owners and they got rid of the computer because it glitched so bad. They wiped the hard drive so the operating system isnt even on...
gtabblt.gif Identifying lock-ups and freezes gtabblt.gif Close locked-up programs and locate problem software gtabblt.gif Uninstall and re-install the problem software gtabblt.gif Contact the software vendor gtabblt.gif Understanding backwards compatibility issues gtabblt.gif Change the operating system emulation with the Program Compatibility Wizard gtabseps.gif This document pertains to HP Notebook PCs with Windows Vista. Identifying lock-ups and freezes This document will help you to locate and troubleshoot programs that cause your notebook to hang, freeze, or lock-up. Print this document or save it to your hard disk drive to have the reference available after disconnecting from the internet. Symptoms of notebook lock-ups, freezes, and hangs include:
  • Nothing moves or blinks on the computer display.
  • The computer will not respond to the mouse or keyboard.
  • An error message appears and will not go away.
Freezes, crashes, and lock-ups may be caused by programs locking up resources, software conflicts, or older programs being incompatible with newer operating systems. Follow the steps in this document, in order, until the problem is resolved. Close locked-up programs and locate problem software If your notebook locks up or stops responding while using a program, close the stalled program to continue using other programs. Also, while closing the program, take note of which other programs are running at the same time.
  1. Close the program that is "Not responding" and determine if the lock-ups continue.
  2. If the lock-ups no longer occur after the program is closed, go to Uninstall and re-install the problem software .
  3. If the lockups continue, press ctrl + alt + delete to go back to the Task Manager.
  4. Write down all of the programs that are running when the lock-up occurs. The conflict could have originated by another software application that is running at the same time.
  5. Close other programs that are running one at a time (except for Explorer and Systray) and determine if the lockups continue. Once you find the problematic software application, go to Uninstall and re-install the problem software .
Uninstall and re-install the problem software To resolve the problem that is causing the notebook to lock-up, uninstall the suspected software and then re-install it. If your software came with an uninstaller program, use it first; otherwise, follow the steps below to uninstall and re-install the program.
  1. Click Start > Control Panel .
  2. When the Control Panel window opens, select Uninstall a program.
  3. Select the program that is causing the lockups and right-click it. Then select Uninstall . NOTE: Remove all versions of the same program. Sometimes upgrades will not remove old versions of the software before installing the new version. This leaves multiple versions of the same software on your computer.
  4. After removing the problem programs, close the Control Panel.
  5. Restart the computer.
  6. Re-install the program following the vendor's instructions
My iBook G4 continues to run slowly and/or freeze
Try resetting the PRAM by turning on the iBook then holding option + command + P + R and wait till u hear another chime. If it still freezes, it may indicate an application may be causing it to lock up hold shift after you hear the chime to boot OS X into safe boot.
1helpful
2answers
Dvd will not eject from my iBook G4
Hold down the Apple and the E when you restart your computer.
2answers
Ibook G4 continually freezes.
reinstall your system.  what system are you using?
1helpful
The computer is locked up (multi colored wheel spinning) t
You can go to the Apple (top left) and on the drop down menu, select "force quit"(which is similar to CTRL-ALT-delete on PC) and quit the program that is locking up.The fact that it locks up with 4 screns oprned tells me that the iBook may need more memory.I believe that the iBooks come with 256 MB. You can add memory and keep this from happening.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
