Whats your phones model number anyway check with this the sim card slot you put may be expanded there will be a small cap like enclosure on the sim slot try to bend it and again insert the sim the sim card should be holded tight or else keep a small paper on above the sim card and close the battery you get a solution. thank you
Hi
Insert the SIM card into your phone. Once your battery is removed, insert the SIM card into your phone. Look at the image on the phone to see how to insert the SIM card correctly. Make sure it is pushed all the way into place.
Replace the battery and turn on the phone. Replace the battery back into its compartment and replace the back cover. Turn on your Nokia 2610 phone, and it should boot up. The name of your wireless provider will appear when your phone is turned on.
Allow time for your phone to read the SIM card. Once your phone is booted up, it will say initializing. This means that it is reading your SIM card information. Once your SIM card is read, your phone will go to the home screen. Your SIM card is now activated, and you should be able to access all of your information.
Please accept the solution if it's helpful. Do get back to us for any further query.
