Camcorder Sharp VL-Z1 will not load the cassette...
I had a Dew problem. so I took out the tape and let the thig dries. Now when I try to insert the tape in, the VL-Z1 ejects it. If I close without any tape, it works (but as camcorder is useless without a tape)
If it is what I think it is, problem will come back, because it has nothing to do with humidity level, it is a faulty connection. If it is what I think it is, problem will come back, because it has nothing to do with humidity level, it is a faulty connection.
You can't post conmments that contain an email address.
Moisture is an enemy of any tape based system. The moisture can cause the tape to "stick" to the rotating heads damaging both the tape and heads. This is why there is a "dew" sensor inside the tape compartment. The screen message indicates that the sensor has detected an excess mount of moisture and won't let the unit load a tape until the problem is cleared. Try leaving the unit open and pointing a hair dryer at it from a distance of about 12"-18". The warm dry air should remove any moisture that exists. Should this not resolve the problem, there is a defect in the sensor and it might need to be replaced.
Dew is likely to form in the following circumstances:
?When moving the camcorder from a cold place to a warm place.
?When placing the camcorder in a cold room which is then heated rapidly.
?When moving the camcorder outdoors from an air conditioned room or car.
?When placing the camcorder in the direct path of air blowing from an air conditioner.
?When placing the camcorder in a humid room.
Dew will gradually form on the head drum of your camcorder and make the video tape stick to the head. This causes damage both to the head and the tape.
When dew forms, recording and playback may not function properly.
When ?DEW? flashes, remove the cassette,leave the cassette compartment open,and wait for a few hours to allow the camcorder to acclimatise to the surrounding temperature.
To use the camcorder again, turn on the power after waiting for a few hours. Be sure that ?DEW? has disappeared.
Do not insert a cassette while ?DEW? is flashing; this may result in damage to the tape.
Dew has condensed in the camera. Eject the cassette but leave the cassette door open.remove the battery . Borrow a hair drier . set it to optimum temperature(not vey hot but but hot enough to cause discomfort when blown on fingers). direct the hot air through the cassette compartment door for about five minutes. reattach the battery and reinsert the tape. Good Luck, Luwangula
xiii
Dew Formation
• What is “dew formation”?
When cold water is poured into a glass,
dew drops form on the glass. This clinging
of water drops is called dew formation.
• When dew forms in your camcorder.
circumstances:
—When moving the camcorder from a
—When placing the camcorder in a cold
—When moving the camcorder outdoors
—When placing the camcorder in the
direct path of air
blowing from an air
conditioner.
—When placing the
camcorder in a
humid room.
• How to prevent trouble.
When using the camcorder in a place
where dew is likely to form, allow the
camcorder and the video tape to
acclimate to the surroundings for about
one hour.
For example, when bringing the
camcorder indoors after skiing, place it in
a plastic bag.
1Be sure to tightly seal the plastic bag
containing the camcorder.
2Remove the bag when the air temperature
inside it reaches the temperature
of the room.
• “Dew” warning feature
If dew forms, the word “DEW” flashes on
the screen, and the power will automatically
turn off in approximately 10 seconds.
Plastic bag
1If “DEW” flashes, remove the cassette,
camcorder to acclimate to the
2To use the camcorder again, turn on the
sure that “DEW” has disappeared.
3Do not insert a cassette while “DEW” is
the tape.
4Since dew forms gradually, it may take
10 to 15 minutes before the dew
warning feature engages.
With the dew indication, the tape will not load. This is to prevent the tape from getting stuck inside the unit. If "drying out" the unit has had no effect, either the sensor itself is bad or the connections to it are defective. Opening these is no simple task for the novice. Bring it in for service. It should not be more than about $100 to fix this problem.
Dan
try to dry up your camera using electric hair blower drier, dew is present inside your camera, but dont overheat the unit, place your hand between drier and cam to make sure you are not overheating it. if the trouble is still there, the sensor is defective and you need pro fix.
Finally, it had to dry completely... I removed the tape, let the cassette compartment open for few days and it's now working.
As easy
