Kodak EasyShare V1003 Digital Camera Logo
Posted on Oct 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Camera keep reseting and doesnt want to start
Pania Lee
Level 3:
Genius:
  • Kodak Master 1,099 Answers
  • Posted on Oct 20, 2009
Pania Lee
Kodak Master
Level 3:
Genius:
Answers
1099
Questions
Helped
218817
Points
1986
My camera doesnt allow me to take photos, the lens doesnt work.
Most of the lens issues due to mechanical problem. some of the causes are dropping the camera.
Hard shake like keeping the Camera in the hand and jump through steps, Moisture condensation, Insufficient battery.. etc If If you feel that the issue is not with the above reason, try initializing the Camera. To initialize the Camera, please use the Initialize option under the setup 1 Menu.
If the issue persists, perform a power reset of the Camera.
Performing a manual power reset Turn off the camera. Remove the battery pack. Remove the button-sized lithium battery. Allow the camera to remain without power for 30 seconds. Reinsert the button-sized lithium battery. Reinsert the battery pack. Turn on the camera. If the issue persist, service is required.
Jan 07, 2011 • Cameras
1helpful
The lens on camera doesnt work
Hard shake like keeping the Camera in the hand while jumping through steps, Moisture condensation, Insufficient battery.. etc If If you feel that the issue is not with the above reason, try initializing the Camera. To initialize the Camera, please use the Initialize option under the setup 1 or Main Settings 1 Menu.
8helpful
My flash is off and when you press the icon it doesnt give the option to turn on
Reset camera by following procedure so flash will start work.
Press Home key -> Settings -> Initialize -> OK
Thanks.
1997 f150 truck starts but doesnt stay running, only if you
sounds like either fuel pump weak or fuel filter plugged
Flash doesnt work, flash icon keeps flashing, E:91:01 flashing
Hi
Try to reset your camera, heres one way of doing it
1. Turn OFF cam & Remove the battery or the power supply
2. Turn the switch to CAMERA for about 30 sec then & Turn the switch to OFF
3. Install the battery or power supply. & Turn the switch to MEMORY
4. Open the LCD cover and press the RESET button ( small inner button )
5. You will be prompt to adjust date/time.
6. Take some pictures and test out your flash
or open up the setup menu, and look for intilize or reset to factory defaults.
That should solve it, if it doesn't then its a hardware issue possibly the flash is bad some parts may need to be replaced to fix it. Take it to a local repairer or your dealer if your in warranty.
www.advancecamera.com will offer a free repair estimate if your outside of warranty.
Htc touch camera doesnt work... did soft and hard reset n tried to start camera app. from windows folder but no response....help needed !
Among the many issues with the Touch, the camera is another. If a hard reset doesnt work, your device will need a new camera. If you have Sprint, this can be replaced at any service center for no charge if you have insurance and there is a part for immediate repair.
Just to confirm, when you do a hard reset make sure that you press and hold both of the softkeys while sticking the stylus in the reset hole until it asks to reset.
2helpful
Samsung D600e. When selecting camera i get the message preview error??
Reboot the phone. If doesnt help, backup the data and do a software reset keeping handy the phone PIN, codes and phone unlock keys.Mail me if doesnt work..
A drop image on screen
hi i have panasonic NV DS 65 initially when i power on the cam it started then after 5 to 10 sec the power light automatically flashes and the buttons on camera doesnt work any more. but now the problem has got worsend the powen light keeps on flashing and no buttons work moreover a drop image is flashed on the screen.
plz have me solve my problem
sam_rav
It keeps making a beeping noise and wont let me record or do anything!
Try taking off the battery and reinserting it to see if it resets mech,If this doesnt work you wil have to bring to service.Dont go at it yourself as you could cause serious problems,
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
