Question about Lexar FireFly 2GB USB 2.0 JumpDrive
When I put the usb in the computer does not see it. I have tried it on other computers and it does not flash and is not seen It was fine yesterday!
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Oct 18, 2009
SOURCE:
My usb device was working fine until yesterday when I plugged it in and I kept getting an Unknown device error with the following message: "Windows has stopped this device because it has reported...
Code 43 errors are nearly always caused by a driver issue. However, since you have tried the device in several different computers with the same result, I believe that your flash drive has gone bad or become damaged. Unfortunately this is not an uncommon problem with flash drives. Like any storage device on the computer, make sure you are backing up what is on your flash drive.
I hope this is helpful to you
May 28, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
Whenever i put a flash drive in any of the usb ports the computer reboots itself.
try putting the flash drive in another computer and if it does the same thing kiss the flash drive goodbye and throw it away.
If it works fine in another computer the problem exists on your USB buss and likely will do the same with any USB device. If this is the case you could try reloading all the USB drivers. If this doesn't help you probably have a short in the USB buss and will have to take it to a local repair facility or contact the PC manufacturer about repair options.
Nov 27, 2009 | Compaq Evo D510 Minitower (Open Box)...
PNY 8GB Flash Drive - PC Will not recognize
Have you installed a scanner/another external USB drive since first trying your Flash drive? If so, try unplugging that and re-insert your Flash drive. I had this problem and a friend suggested this and it worked!
Oct 03, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
SanDisk 2GB Cruzer micro - worked fine yesterday, plugged it in to the same computer this morning, the light flashed on then went off; computer does not see the divice; I have pulled and tried in other USB...
Right click on my computer icon then go to property then hardware then device manager then uninstall all usb drivers .
then right click on any driver then you see scan for hardware click on it then it automatic install usb drivers then restart computer then connect sandisk to computer.then check.
Thanks for using fixya.
If it helps you please don't forget to rate this solution.
Jul 17, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have a 4gb cruzer flash drive and its not working
Okay. Try putting it in on the back of your computer and tell me if it lights up at all, even if it flashes once.
Ryan Frame
Creative Energy Associates Technical Center
Head Technician
Mar 16, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Usb not seen in my computer
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 05, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Flash drive repair
Some times if a flash drive is not ejected, if it is just pulled out, it can wipe all information. I learnt the hard way, make sure you eject each time.  Sorry if this is already known, some times it can be hidden if the file attributes  have been set to hidden. Try looking in you view option and see if they are set to hide files set to hidden.
hope it might help  Mr Fixitcv12
Jul 10, 2008 | Electronics - Others
Lexar FireFly 2GB USB 2.0 JumpDrive Logo
977 people viewed this question
Top Lexar Electronics - Others Experts
Joe Negus
Joe Negus
 Mike M
Mike M
Are you a Lexar Electronics - Other Expert? Answer questions, earn points and help others
