According to the GE manual it is a 120 v 20 watt halogen bulb, the GE product number is WB36X10213. That is the cooktop light/nightlight that would be on the stove hood. HTH!
most grocery stores have them , if you look where they have light bulbs, this one will say for microwaves only on it, easy to change them good luck cost about $3.79
While replacing the cooktop light can be done by accessing the cover on the bottom of the oven, replacing the cavity light will require you to pull the oven from the wall and remove the outer cover.
The installation instructions are very handy in this case, and it's best to have
two people since the microwave can be heavy and awkward.
You can download GE
owner's manuals and installation instructions here.
You can find
helpful exploded view diagrams and order parts by entering your full
model number here.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
That's on page 33 of the owner's manual. If you've misplaced yours, it's archived online here.
Cooktop Light/ Night Light
Replace the burned-out bulb with a 40-watt incandescent bulb (WB36X10003), available from your GE supplier.
1 To replace the bulb(s), first disconnect the power at the main fuse or circuit breaker panel or pull the plug. 2 Remove the screw from light cover and lower the cover. 3 Be sure the bulb(s) to be replaced are cool before removing. After breaking the adhesive seal, remove the bulb by gently turning. 4 Replace the screw. Connect electrical power to the oven.
Oven Light
bulb with a 40-watt
incandescent bulb
1 To replace the oven light, first disconnect the power at the main fuse or circuit breaker panel or pull the plug. 2 Remove the top grille by taking out the 2 screws that hold it in place. 3 Next, remove the screw located above the door near the center of the oven that secures the light housing. 4 Replace the screw. Connect electrical power to the oven.
The bulbs are glued in at the factory. Unplug the microwave and see if you can remove the base of the bulb from the socket with needle nose pliers. You may have to twist the heck out of the bulb base but it should come out. If you do need a new socket it is available at www.geappliances.com under parts and accessories. Or call 1-800-626-2002 for GE factory parts
The control board has been damaged but it can probably be repaired.
We repair this common control board problemn on a regular basis for only $39.95 nationwide.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Feel free to contact me directly if you have further questions.
I appreciate your thoughtful rating of my reply.
The control circuits for the cooktop lights and the hood fan are spearate. The problem is indeed with the control unit.
It's usually caused by either the filaments shorting when the lamp blows or by removing or installing the bulbs while the oven is still plugged into the power line.
We regularly repair these nationwide for $32.50.
Details of our service, as well as *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
What bulb do I use?
