I believe the Mag 36 is a 12v and the Mag 40 is a 24v......Ive been doin a little research and cant find anything that points to a 12 and 24v system.....
There is kind of a collar on the lower side of the head where the head connects to the shaft. There is a single bolt that runs right thru the shaft at this location, remove it. Rotate the head 180 degrees and re-install the bolt. 5 minute job.
look for clips around the pin inside the housing perimiter. If you see rings cut in the pin that don't have clips in them, they probably fell off. If used in a marine environment, the pin probably is corroded and locked to the housing. Use usual methods, i.e. heat and lube and.....a hammer wrench.
