F20 means there is an electrical problem.
Click on this link to go to the manual and look at page 21.
http://www.managemyhome.com//mmh/lis_pdf/OWNM/L0606184.pdf
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Hi
Please
check this link to get error F 20 resolved:-
Please
get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Hi
Error F20 means Water Inlet Problem-no water or insufficient water supply.
This issue can appear due to faulty inlet valves or due to blocked inlet hoses. Also check the filter screen at inlet valve, clean them if they are dirty.
Select PAUSE/CANCEL twice to cancel the cycle. Unplug the washer or disconnect the power. Now check whether water faucets completely turned on?
Make sure that the water inlet hoses are not frozen. If above things seems to be fine then you would need to replace the water inlet/fill valve.
Hope this helps... Please post back if you need more information.
Daniel
