Depending on how hard the grout has set, I would use a small, sharp Cold Chisel and small 2 Ounce hammer, to very gently chip away from the tile surface toward the grout joint.
Be very careful not to damage the tile surface.
Then finish off with some 000 wire wool to polish the tile.
spotremoval.coit.com/how-to-get-blood-out-of-carpet
How do you remove blood stains?Follow These StepsWet the stain with cold water. If the stain is fresh and still wet, soak fabric in cold water immediately.Rub with soap. Rub the stain well with a bar of soap, lathering gently. ...Re-soak the stain with a pre-treatment stain remover. ...Dab on diluted ammonia. ...Launder fabric.How to Clean Blood Stains Video and Steps - Real Simplehttps://www.realsimple.com/home-organizing/cleaning/cleaning.../remove-blood-stainsSearch for: How do you remove blood stains?
or try this link. How to get blood out of carpet Google Search
If the stain is set in, it has already absorbed into the fibers and is not likely to come out.
A last ditch effort to remove it might be tried if it is an organic type of stain- blood, food, grass by soaking it overnight in hydrogen peroxide item fully immersed. If the stain remians in the morning, it is permanent. Dying the grament with fabric dye "might" conceal it, but not very often.
Prevent lint from clinging to clothes by adding 1/2 cup white distilled vinegar to the wash cycle. To remove soap residue that makes black clothes look dull use white distilled vinegar in your final rinse.Get stained white socks and dingy dishcloths white again.
Add 1 cup white distilled vinegar to a large pot of water, bring it to a
rolling boil and drop in the articles. Let soak overnight. Some stains on clothing and linens can be soaked out using equal parts milk and white distilled vinegar.Before washing a mustard stain, dab with white distilled vinegar.ttack spaghetti, barbecue, or ketchup stains with a white distilled vinegar and water solution.Remove perspiration odor and stains on clothing,
as well as those left by deodorants, by spraying full-strength white
distilled vinegar on underarm and collar areas before tossing them into
the washing machine.Forgot that you left wet laundry in the machine and it now smells moldy?
Pour a few cups of white distilled vinegar in the machine and wash the
clothes in hot water. Then run a normal cycle with detergent.Remove smoky odors from clothes
by filling the bathtub with very hot water and 1 cup white distilled
vinegar. Hang the garments above the steaming water and shut the door so
the steam can penetrate the fibers.Keep the steam iron clean and in good working order by
getting rid of mineral deposits in steam vents and spray nozzles. Fill
the water chamber with a solution of equal parts white distilled vinegar
and distilled water. Set it in an upright position and let it steam for
about 5 minutes. When the iron is cool, rinse the tank with water,
refill and shake water through the vents onto an old cloth. Test before
using.Remove scorch marks from an iron by
rubbing it with a warmed-up solution of equal parts white distilled
vinegar and salt. If that doesn't work, use a cloth dampened with
full-strength white distilled vinegar.Remove musky smells from cotton clothes by sprinkling them lightly with white distilled vinegar and then pressing them.Get water and salt stains off shoes and boots by wiping them down with a solution of equal parts white distilled vinegar and water.Give patent leather shoes and bags a better shine by wiping them down with white distilled vinegar.Get cleaner laundry!
Add about 1/4 cup white distilled vinegar to the last rinse. The acid
in white distilled vinegar is too mild to harm fabrics, yet strong
enough to dissolve the alkalies in soaps and detergents. Besides
removing soap, white distilled vinegar prevents yellowing, acts as a
fabric softener and static cling reducer, and attacks mold and mildew.Eliminate manufacturing chemicals from new clothes by adding 1/2 cup white distilled vinegar to the water.Remove soap **** and clean the hoses of your washing machine
with white distilled vinegar. Periodically run the machine with only a
cup of white distilled vinegar in it-nothing else added to the wash
cycle.Bring out bright colors by adding 1/2 cup white distilled vinegar to the rinse cycle.Fluff up wool or acrylic sweaters (hand- or machine-washed) and rid them of soap smell with 1/2 cup white distilled vinegar in the last rinse water. Get rid of the tiny holes left along the hemline
when you take out the hem of any garment by moistening a cloth with
white distilled vinegar, placing it under the fabric and ironing.
What was used for the adhesive? The supplier says do not use thin set, also says use a high quality mastic. I don't know what happened, but it doesn't sound good. Was it just a couple tiles fell off or every tile loose? Was it the grout or the mastic that failed? Did the stone break up? I would like to know what happened.
the problem is your spin program is normal but the machine could not do its job usually there is broken pin clucth under the spinning tube and sometimes the spin gear.this is due to overlload problem. you should brought the machine to your trusted machine repairer as this cost you around US 100-200 in comparison if you buy new one
My book says for the Axxis WFL 2050/WFL 2060 : from the left while looking at it from the front: detergent for wash, stain remover, middle: fabric softener, fabric conditioner, right one: detergent for soaking agent. (Do not use chlorice bleach in this wasking machine).
