Fuses | Rating | Color | Circuit |
Engine bay fuse box | |||
1 | 80 | Black | Power supply to main fuse box |
2 | 60 | Yellow | Radiator fan |
3 | 60 | Yellow | ABS |
4 | 20 | Yellow | Daytime running lights |
5 | 30 | Light green | Fog lamp |
6 | 30 | Light green | Not used |
7 | 30 | Light green | ABS |
8 | 30 | Light green | Air pump |
9 | 20 | Light bue | PCM module |
10 | 20 | Light bue | Ignition switch |
11 | 3 | Violet | PCM memory |
12 | 15 | Light bue | Horn & hazard flasher |
13 | 15 | Light bue | Oxygen sensor |
14 | 15 | Light bue | Fuel pump |
15 | 10 | Red | Right-hand low beam |
Passenger compartment fuse box | |||
16 | 10 | Red | Left-hand low beam |
17 | 10 | Red | Right-hand high beam |
18 | 10 | Red | Left-hand high beam |
19 | 7.5 | Brown | Heated door mirrors |
20 | 10 | Black | Windshield wipers |
21 | 30 | Light green | Electric windows |
22 | 7.5 | Brown | ABS |
23 | 15 | Light bue | Reverse lights |
24 | 15 | Light bue | Brake lights |
25 | 20 | Yellow | Door locks |
26 | 20 | Yellow | Main light |
27 | 15 | Light bue | Cigarette lighter |
28 | 30 | Light green | Power seats |
29 | 30 | Light green | Heated rear window |
30 | 7.5 | Brown | Engine management |
31 | 7.5 | Brown | Instrument pannel lights |
32 | 7.5 | Brown | Radio |
33 | 7.5 | Brown | Front and rear sidelights (left) |
34 | 7.5 | Brown | Interior lighting & clock |
35 | 7.5 | Brown | Front and rear sidelights (right) |
36 | 30 | Light green | Air bag |
37 | 30 | Light green | Heated blower |
38 | Unused |
Relays | Color | Circuit | Location |
R1 | Green | Daytime running lights (Canada) | |
R2 | Black | Radiator fan (high speed) | |
R3 | Blue | AC cut-out | |
R4 | Brown | AC clutch | |
R5 | Dark green | Radiator fan (low speed) | |
R6 | Yellow | Starter | |
R7 | Brown | Horns | |
R8 | Brown | Fuel pump | |
R9 | White | Low beam headlights | |
R10 | White | High beam headlights | |
R11 | Brown | PCM power supply | |
R12 | White | Interior and courtesy lights | |
R13 | Yellow | Heated rear window | |
R14 | Yellow | Heated blower | |
R15 | Green | Windshield wiper motor | |
R16 | Black | Ignition | |
R17 | Unused | ||
R18 | Black | One touch window switch | Driver's door |
R19 | Blue | Cruise control cut-off | Central fuse box bracket |
R20 | Unused | ||
R21 | Unused | ||
R22 | White | Fog lights | Interface module bracket |
R23 | Black | Turn signals | Steering column |
R24 | White | Left-hand flasher | Door lock module bracket |
R25 | White | Right-hand flasher | Door lock module bracket |
R26 | Unused |
Bulbs / Lights | Wattage | Type |
Low beam headlamp | 55 | 9006 Halogen |
High beam headlamp | 55 | 9005 Halogen |
Parking / Side light | 5 | 2357A Wedge |
Front turn signal | 21 | 2357A Bayonet |
Rear turn signal | 21 | 1157 Bayonet |
Tail light | 21 | 1157 Bayonet |
Stop light | 21 | 1157 Bayonet |
High mount stop light | 5 | 2723 Bayonet |
Fog/Driving light | 55 | 893 Halogen |
License plate | 5 | 6418 Festoon |
Reverse light | 21 | 1156 Bayonet |
Front sidemarker | 5 | 2357A Wedge |
Glove box | ||
Map light | 5 | 64111 Wedge |
Dome light | 10 | 6411 Feston |
Step/Courtesy light | ||
Trunk/Cargo area | ||
Engine compartment | 10 | 89 Wedge |
Instrument-general | ||
Automatic trans indicator |
[Information] For a 2002 Toyota Camry, the Daytime
Running Lights (DRL) operate utilizing the High Beams (inner Lamps closer to
the center of the vehicle front) at a reduced power.
[The troubleshooting process:] Review the Owner's Manual and ensure the test
configuration matches the following criteria:
1. According to the 2002 Toyota Camry Owner's Manual (Check your Owners Manual):
"The DRL system will make your headlights come on at a reduced brightness
when:
The light switch s in the "DRL" position.
The ignition is on with the engine running.
The headlight switch is off.
The parking brake is released."
2. Set the Test Conditions according to Step 1 above.
3. Check the headlight bulbs to ensure they are not
burned out. If one burns out, there is a fair chance that the other would have burned
out at the same time. Replace as necessary.
In this case, if the high beams operate, the DRLs should also operate.
4. Test the system, ensuring the step 1 conditions are set. (Engine running, Multi-function
Switch on Turn Signals in "DRL" position, headlight switch off
(repeating what the manual says -- it should be obvious that in the
"DRL" position, the headlight switch should be off / do not have the
switch positioned to "High Beam"), and the Parking Brake
"off").
5. If DRL lights do not work, check the engine compartment Fuse and Relay Box.
there is a 5 Amp DRL fuse -- replace it with the spare. Test (step 4).
6. If it does not work, swap around or replace relays -- there are three (3).
Any one of them could be bad (stuck or burned out). Test (step 4).
7. Other less likely possible issues
could be that the Multi-function Switch is broken or a connection / wire is
broken. [Beyond the scope of this
process.]
My problem was that the test configuration did not have
the engine running and parking brake off - Step 1. Problem solved with much
thought, repetitive tests on the vehicle and going back to the basics -- what
does the Owner's Manual say and where are the applicable fuses and relays
located?
