I have a grohe toilet with the 2 air buttons; the flusher (a silver fixture w/ 2 different flush buttons inside) is not working. the buttons had been stuck all the way in. i took off the cover above and took the plastic cap off the back of that setting (it is one plastic cap w/ 2 small hoses at the top running off to the water basin). i got the button spring to start working again but now there is no water or water pressure so the toilet does not flush. the behind the toilet vantage point from above is pretty tight but i can see the top part of the fitting and get both hands inside to work on it. does someone have an easy explanation on how to fix?
I'm going to just take a wild guess here based on what you said. I have never worked on one of these so bare with me. Your description is good and I think you have some sort of an air lock. I really think that if you just keep fussing with it, it will start working. Check the water inlet as best you can and keep trying to flush and see what happens.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
