The oven on my Inglis Royal II doesn't work. The message given says: E3 -F1-Everything else works...The reset button is O.K. and I can't find any fuse...
F1 - E0
EEPROM communication error
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3.
F1 - E1
EEPROM checksum error
F1 - E2
UL A/D error(s)
F1 - E4
Model ID error
F1 - E5
Calibration shifted
F1 - E6
Latch signal mismatch error
F1 - E9
Stack overflow
F1 - E3
Wiring harness cavity size does not match previously stored value
The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure Disconnect for one minute - if error comes back, replace control board F1 - Shorted control keypad Replace keypad F3 - Oven temperature sensor open Replace oven temperature probe F2 - Oven temperature sensor shorted Replace oven temperature probe F3 - Oven too hot Replace oven temperature probe F3 - Clean temperature too hot Replace oven probe F5 - Door latch switch fault Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop) Replace control board F2 - E0 - Shorted control keypad Replace keypad F3 - E0 - Oven temperature probe open Replace temperature probe F3 - E1 - Oven temperature probe shorted Replace temperature probe F3 - E2 - Oven temp too high Replace temperature probe F3 - E3 - Clean temp too hot Replace temp. probe F5 - E0 - Check door latch F5 - E1 - Check door latch Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error Replace ERC F1 E1 - EEPROM checksum error Replace ERC F1 E2:7 - UL A/D errors Replace ERC F1 E4:2 - Model ID error Reinsert keytail. F1 E6:0 - Latch signal mismatch error Replace ERC F2 E0:4 - Shorted key error Replace keypad assembly F2 E1:3 Keytail unplugged reinsert the keytail F3 E0:5 Top oven sensor open Test and replace top probe. F3 E1:6 Top oven shorted Test and replace temp probe F3 E2:9 Bake range over temperature Test and replace temp probe F3 E3:8 Clean range over temperature Test and replace temp probe. F3 E4:10 Bottom oven sensor open Test and replace temp probe F3 E:15 Bottom oven sensor shorted Test and replace temp probe F5 E0:14 Door switch errot Test and eventually replace door lock switch F5 E1:16 Door latch not operating Test and eventually replace door latch F8 E0:17 Refrigeration error Test the cooling module. PF Power failure - Does not indicate a fault. PF occurs when power is disconnected.
WHIRLPOOL Models SF3, 30'' and 24"
F2 - Oven temperature above specifications Check 8-pin connector from temp. probe to Electronic Oven Control F3 - Open oven temperature probe failure Check wiring, replace oven probe if necessary F4 - Shorted oven temperature sensor failure Check wiring harness, replace oven temperature probe if necessary F5 - Push button stuck or faulty Check for binding of pushbuttons and control panel glass. If OK, replace touch panel F6 - Electronic control logic error (timing) Replace Electronic Range Control (ERC) F7 - Electronic control logic error (lock motor) Replace ERC. F8 - Electronic control logic error Replace ERC.
Hello there and thank you for choosing fixya The E3-F1 ERROR CODE is a fault code that tells the consumer that the ovens main controle panel has a problem This could simply be a wire that has came loose but a lot of the time the controle panel has failed and will need to be replaced Here is what you can do First disconnect the power Totally and slide the oven out and if you can remove the back of the unit and check to see if there are any wires that are loose or really greasy if so clean them and replace them also remove the panel at the top to expose the control board and do the same thing as in the previous step. If you can find the wire harness look for the place where it attaches to the board and disconnect it then wait 30 seconds and reattach it. after this has been completed leave the oven unplugged for at least 45 min total to allow for the internal reset feature to attempt to reset the memory feature on the oven then replace the back of the oven and any other parts that may have been removed plug in the oven and press the cancel button if the error is still showing then yes the board is fried and a new one will have to be installed ok? Hope this is very helpful for you Best regards mike
This indicates a failure in the temperature probe. This is easy to check and replace. Here is a link that will walk you thru checking and replacing an oven Temperature Sensor .If you need diagrams and illustrations of your specific model enter your model their. All parts come with installation instructions.
Hello,the error codes E3 and F1 means Wiring harness cavity size does not match previous stored valued SOLUTION:The "Cavity Size Select"jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size. Thanks
I have an Inglis electric stove with a self cleaning oven We turned the left dial to "CLEAN" and when turned the right dial to clean, a buzzer went off. Can you give me any advise?
I have a Whirlpool oven that is 10 years old or so. The oven stopped working today. The code that came up was E3 (in green) and F1 (in red). I would like to know what is wrong with the oven? Please send me a solution. Thanks
