Duravit Starck 3 Wall Mounted Toilet with Carrier Logo
Posted on Oct 17, 2009
My toilet cistern is continually hissing
I have a Duravit toilet with a Geberit flushing mechanism. I have recently discovered a continual hissing sound coming from the cistern. It will stop occasionally when I flush the toilet but always restarts when I switch on a tap, shower or the washing machine. I have 3 toilets iin the house and the sound only occurrs in the main bathroom. I have also noticed a sliight dripping from the tank into the toilet pan.
Any advice would be great
Kind Regards
Ian Burn
  • 2 more comments
  • Anonymous Mar 11, 2014
    2013 nissan altima
  • Anonymous Mar 12, 2014
    Hi, we have a duravit toilet with a fixed cistern. After replacing the flange at the back of the toilet we have water seeping from under the toilet. Any idea where this could come from? There is no water visibly running down from anywhere.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 31, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
8101
Points
Hi I have exactly the same problem, in fact it could have been me writing this - 3 toliets fine, main bathroom hisses. The Geberit flushing ciphen on the left (the smaller one) has been replaced and there is still a problem. If you look carefully,the water level needs to come up over the lip of an opening on the Geberit part and this causes the valve mechanism to shut off and stop the hissing. It is fine for about 40 minutes and then the hissing starts again if you don't flush it. The reason is that the water level has gone down but there is no obvious signs of where the water is going. It could be that the central flush mechanism is leaking slightly. I am going to replace this part next. If I were you I'd see if you are getting any water leakage into the pan when toilet not in use to see if the water level in the cistern is going down James T
  • scouser-jd Jan 21, 2011
    I had the same problem so I took the flushing valve out and went to get a new one from a plumbing supplies shop. The guy there took the upper section apart to look at the diaphragm, which was damaged. He told me that this is a common problem in parts of town with high mains water pressure. I bought a replacement diaphragm, fitted it and reassembled the cistern and the noise has gone. The guy in the shop said it will probably happen again, and that mixer taps in the house will suffer the same fate unless I get a plumber to fit a pressure limiting valve on the cold water main coming into the house.
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Sep 01, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
12017
Points
Easy! I had the samw problem with my cistren which is Geberit. There is a diaphram in the WC filler valve unit which may need replacing. My plumber gave me one FREE! I replaced the old damaged one and hey presto it's fixed. There is a web site that sell these diaphrams follow this link if it helps: www.toiletspares.co.uk
Cheers! Xmas round the corner!!!!!!!!!!
Hi I have a geberit cistern 222.013.00.1 with hissing noises and tank keeps topping up occasionally
wait for the new washer/ valve to settle in
or turn down the inlet water tap a bit
what does this really mean
tank topping up with water and re filling occasionally
in the wrong way or too tight or the wrong part ?
Nov 09, 2016 • Home
My w/c flush non stop water flow
You need to shorten the flush time of the flush valve.
1helpful
Why is it oveflowing continuously?
maybe your fill valve need adjusting, or replacing, or the flush valve is bad your question is a little broad so it is hard to pinpoint
8helpful
2answers
After cistern refill outflow into toilet bowl continues to dribble in - and you can see a slight flow into the bowl and every so often we hear the cistern refilling a small amount to compensate.
hi i would suggest your ball valve in the cistern needs ajusting remove the top of the cistern you will see the ajustment screw at the end fo the ball **** arm hope this helps
13helpful
3answers
Cannot remove top of cistern
There are some dual flush cisterns where you have to depress one button to reveal a cavity in the second button. Put a screwdriver in that cavity to lever out the second button, then release the first button and prise that out.
Underneath the buttons is a screw which must be unscrewed to release the cistern lid.
Not sure if this will apply to you... but if not, good luck anyway.
17helpful
4answers
Maybe I'm an idiot but I don't know how to get the top off of my
The cistern lid is held down by the chrome assembly (which includes the two buttons that you press to make the toilet flush) sticking up in the middle of the lid. You need to unscrew that (anticlockwise) to be able to lift the lid off, to get to the inlet valve, etc.
If the water is running in very slowly, chances are high that the small screen filter under the inlet valve is partially blocked. Working inside the cistern, you need to unscrew the inlet valve assembly (noting the order in which the various parts come out!), then unscrew the cranked fitting just under that, to get the screen/filter.
Top Duravit Home Experts
Mike Cairns
Mike Cairns
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Duravit Home Expert? Answer questions, earn points and help others
