Ur tv still have dead resistors parts,test all 12 resistors parts around the 2 STK convergence ICS and changes some more dead resistors parts or changes all 12 resistors parts for sure.If tv still have the same problems after tested and replaces more resistors parts or all 12 resistors parts.Than some how when u handling and replacing the 2 STK convergence ICS and resoldering the 2 STK covergence ICS u short it out the 2 STK convergence ICS by resoldering without proper grounding ur self not to allow for static electricity to kill the 2 STK convergence ICS or u using a soldering iron to high of a wattage for doing soldering ICS work.
You have to pull the chasis completly out the set. Make sure you know where all the wires go that u have to unplug. Also u may need to change open resistors near the convergence amplifiers.
HELLO YOU FIRST NEED TO UNPLUG THE SET , THEN TAKE OFF THE BACK OF THE SET. AND LOOK FOR TWO LARGE SILVER HEAT SENK'S THE IC CHIP'S WILL HAVE STK-393-110 ON THEM.!!! WILL BE SCREWED TO THESE HEAT SENK'S WITH SCREW'S AND SOLDER TO THE BOARD ON THE BOTTEM OF THE BOARD,!!! WELL "GOOD LUCK"
some times convergence IC's coused to put set in shutdown unloading the three convergence connectors and trying to turn on the tv if the set turn on the problem is convergence IC's if not check voltage regulator ...if still having problems e-mail me
Ditto CTF1800's comment....Check RP-41 1.5 ohm 2 watt and
other low value resistors near IC's mounted on large heatsinks.
STK392-110 original convergence IC's can be upgraded to
Hitachi # CZ 01341 new number STK394-160E for greater reliability.......Hitachi also has an IC / resistor kit # X480295,
but I don't change good resistors, only the bad one(s).
Practice good visual acuity technique and ask questions!.....T.
The convergence IC`s board location are IK 04 & IK 05. Looking from the back of the TV they are mounted to a large finned aluminum heat sink on the right side of the chassis. The origional part (stk 392-110) can be substituted with an equivalent but higher powered IC (stk 392-180) , that is 180 watt instead of 110 watt chip. Do not use generic IC`s! Purchase origonal Sanyo chips only for best results. Replacement of the chips alone may not cure your problem if there are dammaged resistors caused by the origonal chips. Check the standing resistors on the opposite side of the heat sinks for proper value. RK42(2.2), RK46(1.5), RK58(3.3), RK52(1.8), RK50(2.2), RK54(1.5). All of these low ohm resistors are rated at 1 watt. If you encounter a bad resistor you must replace with the same exact value. Close is not good enough. This should fix your set. Do not buy a policy you have a good TV. Be sure to use a liberal dose of heat sink compound when insatlling the new chips, and clean off the old crusty stuff.
