I have a Whirlpool dryer model LGN2000PWO. It runs too hot even on ''low''. Had a repair man replace cycling therm and hi limit therm and I am still having the same problem. I have tried the timed dry and the Accu Dry both run too hot when it is on ''Low'' and ''Medium''. It's so hot I can hardly touch the inside of the dryer door.
You have an air flow problem. plugged lint screen, dryer vent partially or totally plugged with lint. dryer sheet stuck to the back wall iside the dryer. outside vent cap plugged or not opening. collapsed dryer vent or vent with too sharp of bends in it. and worse case scenario the dryer blower wheel too full of lint. this is provided the thermostats that the tech put in were of the correct heat range and limit.
The dryer is against a first floor outside wall that has less than 2 ft. of venting. The vent has been cleaned out, the lint screen has been cleaned, the outside vent cap is opening, no collapsed vents, no sharp bends. I even took the vent off the back off the dryer and vacummed that out. Any other suggestions?
