Expert
- Posted on Oct 17, 2009
Re: unit builds to 25-30 psi then shuts off. You must
Unhook the output line from the pump. run unit for 5 to 10 min. if no problem, check the tank valve at the end of you out put line, it screws into your tank. that valve must shut off at every down stroke of the piston, or air well flow back to the pump. will put an overload on the motor. good luck
