Hi n5my ,
F1 = Electronic oven control failure
Sol. Replace electronic oven control (also called EOC or clock).
The "F9" error code means the EOC (electronic oven control) has found the lock motor switches to be out of sequence or shorted.
Test switches and if there is nothing wrong then replace the EOC.
both of the error indicates the problem in EOC.
Regards
R.K.
This indicates a failure in the temperature probe. This is easy to check and replace. Here is a link that should help Fault Code F1 F3 F9 Dr. If you need diagrams and illustrations of your specific model enter your model their. All parts come with installation instructions.
This indicates a failure in the temperature probe. This is easy to check and replace. Here is a link that will walk you thru checking an oven Temperature Sensor .
