I have a vizio universal remote and the code that works the vizio sound bar is the first one listed under audio/vizio 0660
Using the remote that comes with time warner cable (Designed by UEI), my code was 1517). Here is what the user manual says...
If you own a VIZIO TV with a Universal Remote that uses a 5-digit programming code, you may program
a device button (such as AUX or AUDIO) with code 31517. If your remote uses a 4-digit code, use 1517.
This will map the Universal Remote button to operate the HD Sound Bar as follows
After much research, here is a step-by-step for getting your Vizio Soundbar to work with the Comcast remote using EFC codes (mine is the newer charcoal grey one, works great!)
Aux - Setup (2 blinks) - 11144 (2 blinks)Aux - Setup (2 blinks) - 994 - Setup - 00169 - Vol Up - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00168 - Vol Down - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00037 - Mute - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00165 - Power - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00164 - Input - Should get 2 blinks
These are optional, I didn't use them:Aux - Setup (2 blinks) - 994 - Setup - 00036 - <button to use for TVOL> - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00101 - <button to use for TSHD> - Should get 2 blinks
Then set the volume control on the remote and other settings according to the Remote's manual.
ENJOY!! Hope this helps someone...
Sorry, here it is again in readable form. My Copy/paste screwed it all up...
I purchase a floor model vizio sound bar without a remote, i have a comcast cable remote....what is the code for the model #593452
This will not work for a Comcast remote with a dark gray center "select" button. Any ideas or help? Thanks.
SOURCE: looking for remote codes for vizio sound bar and
(2 blinks)
them:
(2 blinks)
them:
