Question about Canon PowerShot SD780 IS / IXUS 100 IS Digital Camera
Orange blinking light
I used to use a canon camera before..but i never faced this problem that i face with this model. canon ixus 100. when i click a picture with the flash off an orange light blinks and in the display two hands blinks with a camera between them. Is this some kind of a problem?
    New Friend:
This happens if you are taking shot in low light condition where a camera shake is more likely to happen. use a tripod, or change the ISO to higher value. Using Higher ISO would help less camera shake but the image may have coarse. This is not malfunction.
Posted on Feb 25, 2010
SOURCE:
Canon Ixus 105 got a bit wet, now it won't turn on and indicator light at the back is red/orange??
Sit the camera in sunlight for few hours until its get warm and make sure the battery and memory card out and the doors must be open . After that insert the battery only and try to turn on and see the result.
Aug 07, 2012 | Canon PowerShot SD1300 IS IXUS 105...
I have canon SX 100 IS PowerShot and facing the error Lens Error Restart Camera. Please solve the problem.
The lens error indicates that the movement is inhibited possibly by sand or grit. It also may be misaligned or an internal component has failed. Here are a few links to some other things to try. With newer cameras I am usually hesitant to suggest these options since they include some more extreme procedures that may cause further damage if not done correctly, but since yours is probably no longer under warranty, they may save you an expensive repair bill. An older Canon camera is used to demonstrate these procedures but, the lens structure of these compact cameras is the same so the examples do apply to this unit. These procedures are effective about 60% of the time. Click on or copy and paste the links into your browser.
Lens Covers
* Lens FIX 1
* Lens FIX 2
Additional details also can read in this previous post: support/t10373115-nikkon_s3000
Hope this helps.
Sep 14, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon Ixus 95. When taking pictures of people with dark clothes, the face and background (a stone wall in this case) become white and undefined. Is there a solution?
Sounds like your camera is exposing for the dark clothes and over-exposing the face. You could set the "exposure compensation" down a notch or two in this case for a better exposure.
Nov 15, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
When i go to turn the camera on it says "lens error, restart camera" I haven't had issues till today and it worked just fine yesterday, how do i get this to work?
Try to hold the camera with your right hand with its lens facing the ground. Now, while pushing the on/off button, tap or hit the camera's base on your left palm; do this several times. Chances are, there is a tiny grain of sand or dust build up on the lens' base. It would also help if while turning it on with the lens facing the ground, try to shake it with both hands. Please let me know how this goes.
Aug 17, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
File transfer issue in Canon IXUS 100is.
Try using a separate card reader to download your videos to a folder you create on your desktop.
Sep 17, 2009 | Canon PowerShot SD780 IS / IXUS 100 IS...
Camera was dropped-- "Lens error-restart camera" message
If it is still under warranty , please repair it.
If it is out of warranty. Try to get a quote, it the quote is more than 50% of original value , forget it.
For digital camera's they die like flies. New ones are better and cheaper anyway.
Mar 22, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
Digital cameras
Page 46 of Advanced User's Guide:
Press Menu, select AiAF, set it to "Face Detect".
Dec 27, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon Ixus 75
1. Make sure you are holding the camera very steady when you take the photo.
2. Try increasing the number of pixels resolution to super fine. If this uses too much memory, invest in a larger capacity memory chip. (The one supplied with the camera has a fairly small capacity.)
3. According to the manual, the "portrait" mode softens faces, but there are other modes you can use.
4. Depth of field is pretty much WYSIWYG . Move back and forth and try with and without optical zoom until it looks right.
Dec 26, 2007 | Canon IXUS V2 Digital Camera
Canon PowerShot SD550
yes, the flash of your camera is not charging. needs repair.
Nov 03, 2006 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon PowerShot SD780 IS / IXUS 100 IS Digital Camera Logo
196 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
