No sound from the System, Power light is on the Subwoofer no lights on Satellites, tried each satellites in PC and working although still no light underneath, tried Subwoofer and not working yet power light is on. Checked all speaker cables.
Depending of the type of Subwoofer that required your system.
A) Amplified Subwoofer. (With 110volts A.C. cord attached to the sub)
The subwoofer electronics circuit needs repair or change.
You will find a compatible subwoofer for this type of subwoofer in audio appliance stores.
B)Not amplified Subwoofer (No 110volts A.C. cord attached to the sub)
Bring your sound system to a technician to have the soldering remaked to the devices bolted on the main heatsink.
And have the Subwoofer checked too.
This type of subwoofer can mostly be buy in kit with the satellites speakers.
And need to match thee impedance of the output of your system.
Search for ( 4 ohm or 6 ohm 8 ohm ) near the Sub outlet behind your system.
Hi janros123 - I don't know if this will help - I have a subwoofer ACS48 that needs satellite speakers (they are blown). Want to buy my subwoofer or sell your satellites? I will buy your broken subwoofer, too...thanks, and good luck!
Greg illdooyoo at gmail dot com
Don't know if you've solved this yet but just in case ...
There is nothing to install with loudspeakers - they are independent devices and have nothing to do with your computer.
Check the little lights. There should be one on the back of the subwoofer (by the power switch) and one underneath each of the satellites. If you haven't got the lights under the satellites then you probably have a faulty subwoofer. Check thought that your connections are solid. Remember the two satellites' connectors are keyed and may not be fully home, rotate them slightly until they click completely in.
Theses are excellent speakers and should be deafeningly loud.
Try a re-load of the chipset driver. It is available from the Garmin website. I find that it occasionally becomes corrupt. You can check by entering the "Main Menu" then "Setup" then "System" then press Menu and choose "Software Version". If the "GPS SW Version" is 0.00 then a reload of the chipset driver will correct the problem.
Hi, since you pinpointed the problem, the correct solution would be to replace it. However, if you want to try a temporary remedy, try using a glue gun to put glue around the jack's outer housing while connected to the back panel. Make sure that the glue dries in the correct position (where there is sound from the satellites). It is possible that the sound waves produced by the subwoofer loosens the connection. It might also be helpful if you lock the cable in place so that it will move so much and strain the jack. Regards.
