ASPIRE ONE BIOS FLASH RECOVERY
First format an USB stick with FAT.
Download
the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root
directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's
important. Do not remove the USB stick.
Turn the AA1 off, make
sure both battery and AC adapter are connected. Press Fn+Esc, keep it
pressed and press the power button to turn the AA1 on. Release Fn+Esc
after a few seconds, the power button will be blinking. Press the power
button once. The AA1 will now initiate the BIOS flash, do not interrupt
it under any circumstances. After a while the power button will stop
blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If
for some reason you made a mistake during the procedure and it doesn't
reboot by itself wait 5 minutes before turning it off, just to be safe
that it isn't still flashing the BIOS.
http://support.acer.com/drivers_download.aspxhttp://blog.shimpossible.com/2007/07/18/white-screen-of-death/
Yes I can get into BIOS setup and get a screen with an external monitor connected.
Can you go into BIOS setup and get a screen?
