RTO Mega Motion 3 Wheel Travel Pal Scooter Logo
Posted on Oct 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After the key is inserted, I hear 7 beeping tones and the scooter doesn't move.
Rob Hill
Level 3:
  • RTO Master 1,480 Answers
  • Posted on Oct 17, 2009
Rob Hill
RTO Master
Level 3:
Answers
1480
Questions
0
Helped
518149
Points
3838
I have repaired a scooter with the same problem, it normally the rear part of the motor connections, like string loaded connectors, you will need to gently rough up the connecters so a good connection is made , also below the bike there are the main wiring connecters again remove the connectors then reinsert, this is normally a bad connection problem. where the read disconnects to the main scooter is the main area of connection problems.
Regards
GeWiz.
Lights will not turn off and after turning on scooter in a few minutes, hear a beeping
If the lights on your Golden 3-wheel scooter won't turn off and you hear a beeping sound after turning it on, it could indicate a potential issue. Here are some troubleshooting steps you can try:
  1. Check the key switch: Ensure that the key is inserted fully into the key switch and turned to the correct position. Sometimes, if the key is not fully engaged or turned properly, it can cause electrical issues. Try removing the key, reinserting it, and turning it to the correct position.
  2. Examine the battery connections: Inspect the battery connections to ensure they are secure and free from corrosion. Loose or corroded connections can affect the scooter's electrical system. If you notice any loose or corroded connections, carefully tighten or clean them as needed.
  3. Verify the charger connection: If the scooter is connected to a charger, make sure it is properly plugged in and connected to the scooter. A loose or faulty charger connection can cause electrical malfunctions. Try unplugging and reconnecting the charger to ensure a secure connection.
  4. Check the scooter's manual: Refer to the owner's manual or user guide for your specific model of Golden 3-wheel scooter. It may provide troubleshooting steps or information about the beeping sound and lights issue you are experiencing. Look for any error codes or indications that can help diagnose the issue
Fortress 2000 AT mobility scooter. it won't move and I'm just getting a continuous beep after inserting key.please advise.
hi , do you know the name of the controller that installed o n that scooter ? is it a silver , or black or blue ?
Look a the status light ? on the tiller is it flashing ?
Regards
Rob
1helpful
I have a Pride 4 wheel Go Go Elite Traveller Scooter. It generally works fine, but I will frequently get an 8 beep error code and it won't go after a stop. I merely turn the key off and then
BEEP CODE CONDITION SOLUTION
2 Battery voltage is too low to operate Charge the batteries fully until charger and
the scooter. any meters indicate completion.
3 Battery voltage is too high to operate Contact your authorized Pride Provider for
the scooter. assistance.
5 Solenoid brake trip. The manual freewheel Remove the key, then push the manual
lever may be in the freewheel position. freewheel lever to the drive position and
restart the scooter.
6 Throttle trip. The throttle control lever Release the throttle control lever completely,
may have been depressed while inserting then reinsert the key.
the key.
7 Throttle trip. Throttle potentiometer Contact your authorized Pride Provider for
fault or speed potentiometer fault. assistance.
8 The motor is disconnected. Contact your authorized Pride Provider for
assistance.
9 Possible controller trip. You may be Shut down your scooter for a minimum of
attempting to install the battery pack while several minutes to allow the controller to
the key is inserted or the motor controller cool. Or, try reinserting the key into the key
may be in overheat protective mode. switch.
What you may be doing is mis-counting the beeps and it may be 9 beeps or its 8 and you have a bad connection between the motor and the switch? Good luck!
Regards
Rob
When I want to get scooter to go, it just beeps.
2 beeps=too low battery voltage
3 beeps=battery voltage too high
5 beeps=solenoid brake trip or free wheel mode
remove key then push then push the manual release lever in completely
6 beeps=throttle trip
throttle control lever may have been depressed while
inserting key so release control lever completely
7 beeps=throttle trip
throttle potentiometer fault or speed potentiometer fault
2helpful
2answers
How to stop a continuing beep on my Cordoba scooter when I turn the key on? The scooter don't move at all.
Hi Mag,
I have this steps that might help you with beeping sound on your Scooter. Hope it helps.
UNIT LIGHTS UP/HORN WORKS BUT UNIT WILL NOT MOVE
Possible Cause:
  • This often occurs when the scooter is in free wheel mode and is not in drive mode. Re-Engage the free wheel lever which is located down near the rear wheels (normally a yellow or red lever).
  • If you hear a beeping noise, the beeping you hear is a fault beep indicating the scooter main control box has detected a problem. Contact your dealer who can diagnose the beep code.
  • Check batteries with load tester - If either battery drops more than 1 volt under a load, the battery(s) are bad. Replace "both" batteries.
I also find these additional steps on how to know beep alarm indicators:
This main control box has a self-diagnostics feature & cannot be tested with a volt meter. When a
problem is present the main control box will diagnose the fault, prohibit the scooter from being driven
and sound an alert beep. Each alert beep indicates a different issue which helps to determining the
problem by narrowing the fault into one of a few main areas of the scooter. Reference this information
below for the alert beep indications.
Very Rapid beep- Batteries are low. Charge & test batteries.
Medium Fast beep- Motor/brake wiring fault. Free wheel lever disengaged.
Solid beep- The charger is plugged into the scooter (some models may vary).
Very Slow beep- The throttle pot was not at center when you turned the unit on. Throttle pot off
center or wiring (yellow & orange wires) fault.
2answers
Scooter does not move either direction. when i insert the key i get 10 fast beeps and the 9 slower beeps
This scooter has an S drive controller. The beep code will begin with 10 very fast beeps followed by a number of slower beeps. The number of slower beeps indicates the actual code. It will do this only once. To repeat the beep code, remove and reinsert the key.
Beep code #9 is a possible controller trip.
Diagnosis:
The key may have been inserted during battery box installation.
The controller may be overheated.
The brake is dragging or pulling too much current.
Solution:
Remove the key from the key switch before installing the battery box.
If the problem persists shut down the scooter for 10-15 minutes and allow the controller to cool down.
Bottom line is that you may need a new controller or brake. Keep in mind these may be warranty items. A qualified technician may be needed to diagnose and repair the problem. Hope this helps.
1helpful
I have a milan mobility scooter,turn the key & it sounds a low
Hi. This sounds difficult. I have had a few scooters move slowly forward or in reverse, but not both. Normally if the speed pot ( wig wag ) is not exactly in the central position, they can do this.
It is possible for a scooter to have your problem, if the speed lever is binding or rubbing on the housing. Normally the lever is returned to the middle by a spring around the speed pot shaft. If this spring is loose or broken, then this could also cause the problem. Sometimes a small spot of oil or grease will help.
To check the speed lever is in the middle, slowly move the lever for forward untill you hear the brake solenoid release. Now release the lever and slowly pull it for reverse untill you hear the brake solenoid release. Make sure that the speed lever moves the same amount for forward as it does for reverse. If not adjust it with the key off.
If you get the machine to drive properly, then change the controller to see if it is OK.
As for the beeping, a lot of machines will go into an error mode if the speed lever is not in the central position when you turn the key on. This is a safety precausion.
Good luck. Neil.
Top RTO Health & Beauty Experts
Rob Hill
Rob Hill
Thomas Perkins
Thomas Perkins
Harsal Patel
Harsal Patel
Are you a RTO Health and Beauty Expert? Answer questions, earn points and help others
